Samsung le40n71b goes black after 2 sec
Re: Samsung le40n71b goes black after 2 sec
Once you test the DC output from the Diodes, then you may try reseating the lamps, it looks like the lamps are socketed in place.Never stop learning
red probe on single point like arrow in photo.
black probe on gnd.
about 7.35 volt on every diod
It does not look the same on my set like in the video.
If I want to try the AC test.
Is that possible and where to set the probes than?
You mean reseat the tube?
Disassamble everything like in video number 2?????
Cant I do the jumperthing like he does?
It seems like I do not have a transformer for every tube like he did?
Or is it one transformer for 2 tubes in my case?Comment
Those are the correct Diode, I expect the one with bad lamp will show higher reading than the rest.
I really do not like to have you take the panel completely apart to get to the lamp due to more chance of breaking the lamp or the screen.
Not sure abut the jumping the transformer, I need to look at the pictures of the board that I download to see how they are connected first.Last edited by budm; 05-11-2015, 04:57 PM.Never stop learning
But do you think that a bad seated tube is the problem.
is 7.35 ok. In the video he had much less I believe.
Is it like one transformer is for 2 tubes in my set?Comment
Since it is not the exact same design, the Voltage level may not be the same, but since we are looking the Delta of the Voltage to see if any one of them shows differently but we are not seeing it. The Voltage at LD pin is the errors signal and normally should be >11VDC, <10V = error. I need to study more to see what is going on, may be I can find training manual for this series.Never stop learning
Since it is not the exact same design, the Voltage level may not be the same, but since we are looking the Delta of the Voltage to see if any one of them shows differently but we are not seeing it. The Voltage at LD pin is the errors signal and normally should be >11VDC, <10V = error. I need to study more to see what is going on, may be I can find training manual for this series.Comment
1) Can I get really clear straight shot of the this connector to see where LD pin connection goes to?
2) Please put the DCV meter on the LD pin and see when power switch is activated it is at 12VDC and then see if it drops down when the backlghts go off.Never stop learning
did not see that when I did reading earlier. Sorry.Comment
"The reading on LD pin is 6.5V when I turn on the set. When the backlight lid it goes to 0V for 0.5 seconds then goes back to 6.5V when the backlight fail." OK, that does not sound right, but you do have 13V on that connector, right?Never stop learning
I think it was about 0,8V on standby on the LD-pin with the connector connectedComment
When TV is turned on. There is a 13V pin on that connector. The LD signal is generated by the comparator circuit that either at >11V (GOOD) or <1V (LAMP ERROR).Last edited by budm; 05-13-2015, 08:27 AM.Never stop learning
I have look and see if I have that spare balancer board some where.Never stop learning
ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
BTW, you may want to read this while I do more research, see page 45.
We may be able to fool the LD pin for testing purpose.Attached FilesNever stop learning
Yes I can try to put a jumper between 13V and LD ? not as final sollution of course, just to test if it stays on.
Do you think anything else will break ?
Note also that I have a Samsung and this training manual is for SONY.
But I guess it works the same?
Is there a training manual like this for Samsung perhaps?Comment
You have to remove the LD wiree from the inverter board connector first and then use 1K resistor between the 13V and the LD wire that you just remove from the connector.
SONY and SAMSUNG were working together on the TV design. You will see SONY/SAMSUNG 'S' I forget the name of the two companies use. I look for SAMSUNG Training but did not find the one for this chassis.Never stop learning
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
- Loading...
