KDL-50R550A pulsating horizontal blurry lines
  • DaneRoger
    • Apr 2015
    • 3
    • Trinidad
    I have a sony tv (KDL-50R550A) which began to show pulsating horizontal blurry lines. The store recommends getting a new tv since this model T-Con board is built into the screen. Purchasing and shipping this part may cost just as much as a new tv. This tv is only about 2 years old. I plan to repair this tv for myself. I am requesting information that may assist in identifying the repairing this problem. Thanks.
  • DaneRoger
    • Apr 2015
    • 3
    • Trinidad
    Re: KDL-50R550A pulsating horizontal blurry lines
    Requesting assistance in locating the maintenance manual for sony KDL50R550A. Thanks.
    • jamesb6
      • Nov 2012
      • 20
      It is probably not the T-Con. Likely a bad panel. If you want to try a T-Con, you can get one on Ebay. The T-Con model is 6871L-3339A. The store told you it was part of the panel because Sony purchases the panel and it cones with the T-Con attached. Sony does not make the part and does not stock it.
      • lalin
        M
        • Apr 2015
        • 20
        • us
        That I know horizontal lines are not caused by tcon problems, it may be the tabs on the side next to the inverter board that connect to the lamps or the inverter itself, on the inverter it may be the transformers. Sometimes it may be the logic or main boar but it will never be the tcon board, if you replace it please let me know how it went.
        • anmol
          • Mar 2012
          • 73
          • India
          I think this is Edge LED Panel. not CCFL Panel.
          @ lalin,
          please upload clear photos of picture and tcon PCB.
          wbr
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • Ihandyrepair
            Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
            by Ihandyrepair
            Hi guys
            I just started fixing 4k TV few months ago. so I am still learning a lot
            I got this tv from friend complaint is ghosting or horizontal lines on image.
            never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
            then it started to show the ghosting white image.
            I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
            it has 3 thin small boards at the bottom of the...
            12-05-2022, 04:18 PM
          • ggil44
            Sony XBR-65X750D Horizontal lines bottom of screen
            by ggil44
            Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
            05-30-2023, 07:51 PM
          • noisykid
            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
            by noisykid
            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
            12-30-2024, 07:15 PM
          • noipi
            samsung Oled 65 Horizontal Lines and Flicker
            by noipi
            I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
            10-14-2025, 02:11 AM
