hisense HLS106T69PZ missing lcd/on/off voltage
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    all voltages are present from ps except the lcd on/off voltage, connection xp812, 10th pin down.
    when starting from the touch pad, the voltage goes from 22mv to 61mv.
    at this point all other voltages are stable and present, but the backlights are not present and with a torch, no image is on the screen.
    i can jump the ps with resistors and the backlights work fine.
    this must be a common fault, as i have 3 or 4 of them here, all in the same state.
    thanks for any guidance.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: hisense HLS106T69PZ missing lcd/on/off voltage
    Mainboard.
    PSU provides 5v Standby.. Main sends >2.5v to PSU when power button is triggered.. PSU receives >2.5v at ON/OFF pin and starts all other voltages.
    So Main isn't sending ON/OFF signal.
    • attainteddragon
      • Apr 2013
      • 764
      • australia
      that was my thought, but as always, i would love to track the problem down.
      i was trying to trace the signal, but main boards are a pain.
      • Jay W
        • Jun 2015
        • US
        I have the same exact issue with a Dynex(Hisense) main board. I have so far discovered that when the TV is first plugged in, the standby LED is lit. This made me think it was in full standby mode. Then I noticed that almost all of the components on the main board had voltage, like it thinks it is turned on. The power board connector shows that the 5,12, and 18 volt wires are energized. I dont have it right here but I believe PSU and STB are sitting at 0 volts, instead of having 3v when it would run normally.
        On the power switch connector, without the power switch connected, it does not show the expected 3v, 3v, ground, 3v at the main board. Instead it shows lower voltages and the ground appears to have some voltage.
        My current theory is that the strange voltages at the power switch connector are telling the processor to turn some things on when the TV is first plugged in, but not all, and the backlight and LCD are not up while the rest of the TV is powered on. Plus it is not really in standby mode like it should be.
        And even though most of the TV is powered up, the CPU is confused and thinks it is not really in standby, so pushing the button does not get it out of standby. I will start tracing down the low voltages at the power switch connector to see if I can tell where that is originating. I have a similar working Hisense board that allows me to compare voltages.
        So far I have changed the EEPROM and several of the main board electrolytic surface mount capacitors, but not all of them. Nothing yet has gotten it to work as I just discovered the odd voltages after changing some things.
        • attainteddragon
          • Apr 2013
          • 764
          • australia
          Have you tried to jump your power supply on to see if your psu is putting out the correct voltages and that your inverter is working properly.
          I have recently discovered that hisense have an office not too far from me, and i will be contacting them shortly to see if they can shed some light on this issue, or offer a repair for it.
          • CapLeaker
            Leaking Member
            • 8213
            Try taking the on / off pin out and jump the PSON pin on the PSU through a 1k ohm resistor to STBY voltage. Why taking the pin off? because you don't want do back feed voltage and maybe fry more. Now you control on / off, not the main board.
            • attainteddragon
              • Apr 2013
              • 764
              • australia
              I did think about trying something like that, but i wasn't sure if i could get away with it.
              I can remove the ps on pin from the loom to protect the main board.
              I'll put it back on the bench tomorrow and have another look over it.
              Thanks capLeaker.
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                Well, here is the update.
                With the ps pin removed from main board loom and fed back to stby,
                the back lights come on, but there is no display information. No signal, volume control, channel change etc. So I'm assuming that the ps on voltage also has other signaling paths on the main board.
                on a good note, i dragged out another one of these sets and it is currently working, so i can get some running voltages to help assist a little.
                Whatever is failing must be just out of the sets tolerances as this set had the identical fault when i last looked at it.
                • CapLeaker
                  Leaking Member
                  • 8213
                  Ok. To check the main board out, look with an oscilloscope at the LVDS, while flicking the menu on off all the time. You should see a signal change. Look at the T-Con board for blown fuses etc.
                  • attainteddragon
                    • Apr 2013
                    • 764
                    • australia
                    This is my first time using a scope, so I'm taking my time to try and get things right.
                    With the on signal jumped, there is voltage on the lvds, but no data.
                    I also scoped the working set, and the data for the tv, having no signal, is clearly visable.
                    I then put the working main board into the faulty set to make sure there were no issues with the tcon and panel, and they are all good.
                    • crot69
                      asus x453sa missing all voltage except 19v and charging pin
                      by crot69
                      Hi, my friend have this laptop
                      Before all voltage missing, im already repair this laptop 3x (i have 3 of this laptop and all of them dead, can't be repaired because dead CPU and other component due unknow chips, why always asus laptop have this issue).
                      1st repair it short at 3vsus (dead low side mosfe and short caps)
                      2nd repair short at CPU Vcore mosfet (low side)
                      3rd repair 12v missing (only 1.2v but it can run bios and hdd not detected because 3vs missing).
                      and then after 3x enter BIOS it blank then dead (all mosfet buzzing, 12v still missing)
                      11-23-2022, 09:51 PM
                    • Stephen
                      MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                      by Stephen
                      I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                      02-06-2025, 12:03 PM
                    • Lucifer87
                      rx 5700 pulse Schematic & Boardview request 1.8 missing sometimes present
                      by Lucifer87
                      Hi, I need the schematic and boardview of a Radeon RX 5700 Pulse, sometimes it turns on, sometimes it doesn't... I checked when it doesn't turn on, the enable signal is missing on pin 15 EN2 3v to power 1.8v... the problem is that when it works I can't test it since the signal is present... I would like to check the signal paths but I would need the diagram and the boardview thanks​...
                      12-15-2024, 12:29 PM
                    • LeeBa
                      ASUS ROG Zephyrus GA401IV - It won't start - voltage present after repairs
                      by LeeBa
                      please I have this APL6012 circuit on my NB defective - it heats up. I soldered it but the NB still won't start. All voltages are present - except for battery charging.
                      The NB can be turned on, the keyboard lights up, the current consumption is slightly over 1A. All voltages are present. But nothing happens. It's just that as everything heats up, the current slowly increases.
                      Should the NB turn on without this circuit or does it need it to start? I don't know if that circuit communicates with the EC.
                      Thank you very much for your responses.
                      Libor​...
                      12-28-2024, 10:20 AM
                    • Kooopa
                      Acer Nitro 5 EC_RSMRST# present, Missing SLP_S5#!!!
                      by Kooopa
                      Hi! I'm diagnosing my Nitro 5 AN515-43 Mobo: FH50Q LA-J621P. I left it on sleep mode but when I came back It won't turn on. Power LED would turn on for a few seconds then off. no fan spin nor keyboard backlight.
                      So I tried the usual procedures first, power cycling and bios reset but non did the trick so I decided to delve deeper.
                      Nothing strikes as red flags aside from the dust. there's no history of any liquid being poured at it since I bought the thing, I've been real careful. Anyways.
                      I checked the usual rails +5VALW +3VALW even the 1.8VALW and 0.9VALW...
                      09-06-2024, 11:38 AM
