Viewsonic N3252W No display
  • benV
    • Sep 2011
    • 47
    My Stepfather gave me his Viewsonic N3252W to (try) fix it. Suddenly, one day, the display went off. The power button stay green and the sound work but that's all. I already replaced a NKS N3856VG chip on the under side of the power board because the area around was brown (heat) and because i found some people talking about this possible faulty piece.
    After that, i took pictures of the board and i made measurements. Here they are:
    To the logic board CN801 :
    number color power off power on
    1 black 0 0
    2 black 0 0
    3 black 0 0
    4 black 0 0
    5 yellow 0 2.49V
    6 yellow 0 2.49V
    7 red 5.15V 5.12V
    8 red 5.15V 5.12V
    9 red 5.15V 5.12V
    10 brown 60.8MV 3.49V
    11 orange 0.623V 4.86V
    12 blue 6.2MV 4.87V
    To the inverter board (i think) CN701 :
    1 light gary 6.2MV 4.87V
    2 gray 0.62V 4.87V
    3 purple 0 104.7MV
    4 blue 0 104.8MV
    5 green 0 104.9MV
    6 yellow 0 105MV
    7 orange 0 0.1MV
    8 red 0 0.1MV
    9 brown 0 0.1MV
    10 black 0 0.1MV
    I hope that those numbers will help you to help me ;-)
    Thanks.
  • paulstef
    • Dec 2013
    • 724
    Re: Viewsonic N3252W No display
    I have a 3752w right in front of me. Completely different boards but same symptom.
    There seem to be no voltage (about 24V) going to the inverter board. That's connector CN701 according to you.
    You also need to find out which signals control the backlight (assuming it's the backlight that doesn't turn on). CN701 pin 1 and 2 look like good candidates.
    But first you need to find out why there is no 24 or similar voltage. Looks like a problem on the power board. Check for visible damages, cold solder joints, check FETs and diodes first.
    • lostone
      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
      by lostone
      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
      05-19-2024, 11:40 AM
    • StefanNg
      Viewsonic VX2718-PC-mhd SG2701B01-8
      by StefanNg
      Hi, Badcaps.
      I am troubleshooting a monitor
      Viewsonic VX2718-PC-mhd.
      Panel model SG2701BSG2701-8
      Symptoms is no image.
      This panel has 2 panel board connected by a U-ribbon.
      When I disconnected the ribbon, I get a perfect half screen image.
      I took some test point voltage, when ribbon disconnected.
      HVAA 8.38v
      FVDD12 1.21v
      FDD33 3.3v
      VIN 11.79v
      VAA 16.85v
      VGHF 30.16v
      VGL -8.02v
      CK1_I ~ CK8_I 1.403v
      CK1_L ~ CK8_L 8.26v
      When I connect both panel board
      HVAA, VGHF, and CKx_L...
      05-17-2025, 01:43 AM
    • Fagauthier
      Viewsonic power supply model #EADP-64BF B Need circuit diagram…
      by Fagauthier
      I have à defective Viewsonic monitor. I can't find a circuit diagram for it' power supply.
      Model #EADP-64BF B
      The user manual have all diagram except for the power supply. I would appreciate help to find the circuit diagram, thanks...
      07-08-2023, 08:02 PM
    • Returning Buick
      Viewsonic G810 vertical deflection problem
      by Returning Buick
      I have a G810 monitor i've had for years but it has developed a problem with vertical collapse. Is there anybody here who has worked on these and can help me find where the circuit even is for the vertical deflection?
      04-01-2025, 07:57 PM
    • RetroComputingGrotto
      Viewsonic VA2010wb (High Pitch Squeal At Power On)
      by RetroComputingGrotto
      I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
      On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
      The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
      What component(s)...
      02-03-2025, 06:00 AM
