Samsung PS43E450
  • Hamie
    • Apr 2014
    • 1383
    Samsung PS43E450
    Working on this Samsung TV today.
    Initial fault has been repaired faulty X-Main.
    Repaired the x-Main, four shortet surface mount IGBTs - RJP30H1
    So now the TV fires up, however it has 3 horizontal pixel width black lines.
    I resat the connections and gave them a good clean but no joy.
    A replacement buffer was only £5 so though worth the gamble and ordered it from that trusted market place that is eBay.
    Anyway buffer arrived today so before installing it I tested it and of course it was shorted so pointless installing it in the TV.
    Question is, if i remove the bad buffer IC will the TV power up and display an image? (obviously with distortion/horizontal black bar where the IC would have been. Or do the more recent plasmas now shut down when an IC is removed?
    It would save me the bother ordering another buffer if the original black lines remained.
    Re: Samsung PS43E450
    It should power up without the IC, but the picture above/below the IC might be missing.
    Lines from left to right and top to bottom, plasma or LCD, are almost -always- the panel, unfortunately.
    Samsung really, really cheaped on on their late model budget plasmas...
    • Hamie
      • Apr 2014
      • 1383
      Yeah I know, had a few plasmas with horizontal lines and just reseating the connections fixed it, but for a fiver I thought what the hell.
      I'll remove the IC and update soon.
      • Hamie
        • Apr 2014
        • 1383
        Unfortunately after the ICs were removed the TV did go into error detect and the control board started to blink once every 6 or so seconds. Nothing on screen.
        So I'm guessing that more recently plasmas won't power up fully with an IC removed.
        Damn.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          I have one it atm with a shorted plasma panel horrible samsung crap :L
            09-07-2024, 05:50 AM
          • Rubenlily
            Samsung QE50Q67TAU - horizontal lines
            by Rubenlily
            First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
            I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
            I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
            I'm no expert but I've done the tape...
            08-16-2023, 01:12 PM
          • jeyoung12
            Samsung QN50Q60t lines on screen
            by jeyoung12
            Hi all
            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
            So....i don't know what end of the C ribbon to work with...
            02-26-2024, 10:38 AM
            09-06-2024, 11:40 PM
