Lg smart tv 47ln5700 HELP WITH BAD LEDS.
  • mattstolte
    • Dec 2013
    • 612
    • usa
    ok so i got this tv and with the help of you fellows i learned that the reason this tv would light up then go black was due to bad leds, so i take it apart and i have 3 rows completely out. Row 3,4,5 are all out and 1 led in top middle. So is there part numbers u have to order from these? Ive never did this before
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Re: Lg smart tv 47ln5700 HELP WITH BAD LEDS.
    Ok i figured out the part numbers i need 8 strips
    3 of 6916l-1176a
    2 of 6916l-1177a
    2 of 6916l-1174a
    1 of 6916l-1175a
    i found 2 sets of them for 24.00 per strip. Which at that rate this will cost me 200 to fix. Plus there 2 sets i couldnt find on ebay. Does anyone know any places to order these?
    • mattstolte
      • Dec 2013
      • 612
      • usa
      I dont see how all them leds could of went bad?
      • JeffJ
        • Apr 2012
        • 189
        They may not be all bad. they are wired in series so a single bad led will stop anything in that series from lighting. I had a bad L1 strip and it stopped all 4 strips in its series from lighting.
        • mattstolte
          • Dec 2013
          • 612
          • usa
          Well i got 1 led in the top middle out and it dont stop them whole strips from being out?
          • JeffJ
            • Apr 2012
            • 189
            you cant just remove LED strips and expect the others to power and stay on. one bad led will cause all of them in that series to not light at all. They are in series and the power supply is looking for proper Vf. You are going to have to test the strips individually to find what ones are bad if its not visually bad. I typically use 9V 600mA to test led strips. They are delecate and can blow easy so constant amperage is key. Others use 12v i have seen as well.
              https://www.badcaps.net/forum/showpo...27&postcount=5
              I do not think Matt understands what series and parallel connections mean.
                LEDs can fail short and open. If they fail short, they do not emit light but the rest of the strip works still. If they fail open then they also do not emit light but also prevent the rest of the strip from working.
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  To add to the problem.....
                  You cant buy the LED's anyway--Or the strips that are used....
                  Best you can do--is grab some from a broken-screen set with similar/same LED strips....
                  The Makers consider the entire screen assembly as one piece, with no internal parts available separately....
                  TELEFIX
                  • JeffJ
                    • Apr 2012
                    • 189
                    with the proper tools one could repair a bad led strip i assume. I should give it a go.
                      Only if you can find matching LEDs...
                      • JeffJ
                        • Apr 2012
                        • 189
                        Well. I have a L1 strip from this same model that i just repaired. It has one bad led on it. I also have another L1 strip that the Ebay seller sent me first that was mangled. If it has a working led on it i could try a transplant and have my self a backup led strip. If it fails, well they were both going in the bin anyways.
                        • mattstolte
                          • Dec 2013
                          • 612
                          • usa
                          IMA kinda lost here. Seems like a lot of new information I have never done any of this but if you guys don't mind I would like to learn it and give it a shot
                          • newtothis
                            • Mar 2013
                            • 1556
                            • england
                            I've replaced a few LED's on strips... Some are easier than others and some seem damn near impossible!
                            Some I have done with an iron, others a HA station... Some have required IR as the LED/Strip won't tolerate the HA
                            • JeffJ
                              • Apr 2012
                              • 189
                              Matt, if you have indeed tested that led strips properly and they are actually bad. With that many bad LEDs i'd part the TV out. If you feel you haven't tested the leds properly and need more help doing so post back. But that is a WHOLE lot of leds to be bad all at once. I have never seen that many bad at once.
                              • mattstolte
                                • Dec 2013
                                • 612
                                • usa
                                No I haven't don't any testing LEDs. I never done this before nor know how all I did was kept turning the power on the TV to see what led light where out. This strips are divided in half by right side and left side. How do I go about testing them
                                • mattstolte
                                  • Dec 2013
                                  • 612
                                  • usa
                                  how do I began to test this leds?
                                  • newtothis
                                    • Mar 2013
                                    • 1556
                                    • england
                                    mattstolte sometimes if your meter is powerful enough you can set it to diode mode and touch your probes to the contacts of the LED, you may find they light up very dim
                                    • mattstolte
                                      • Dec 2013
                                      • 612
                                      • usa
                                      There are no contacts on the back of these leds
                                      • newtothis
                                        • Mar 2013
                                        • 1556
                                        • england
                                        I remove the LEDS from the strips when I cant see the contacts... I have managed with HA on rare occasions and can do it fine using IR
                                          HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch EliteDesk 800 i5-9500T Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch boardview and EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch boardview and ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          HP ProDesk 600 G5 + Fitbit Versa Smart Fitness Watch ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                        • Pipolups
                                          Corsair K70 LUX RGB dying LEDs
                                          by Pipolups
                                          Hi there !
                                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                          10-08-2024, 11:58 AM
                                          HP EliteBook x360 830 G6 + Fitbit Versa Smart Fitness Watch Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 830 G6 + Fitbit Versa Smart Fitness Watch Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Fitbit Versa Smart Fitness Watch boardview and 830 G6 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-06-2024, 12:00 PM
