TH42PX60U Vertical Color bands
  • rustytierod
    • Sep 2014
    • 81
    Wondering if this is panel failure? The colors of the lines change and sometimes it's a solid black bar the same width.
    Could the buffer boards have been affected?
    Thanks in advance!
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: TH42PX60U Vertical Color bands
    Panel Fault
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Panel issue--or more acurately, the COF chip attached to the panel on the Mylar film--They are made as an assembly and cannot be replaced separately.
      You'll probably find that the chip's heatsink directly under the faulty area is hotter than the others....
      I remember scrapping Three of this model for exactly the same issue--In One Day!
      TELEFIX
      • rustytierod
        • Sep 2014
        • 81
        Wow, thanks!
        • Shinju
          • Mar 2014
          • 1239
          Well, at least try to clean and reseat the affect ribbon cable to see if that clears it up, but that does look like IC failure.
          • lowteq
            Partial Success Repairing Vertical White Bands on HP Z30i
            by lowteq
            Hello.
            I was given a HP Z30i LCD computer monitor that had several white wide vertical bands on it. I had another Z30i that was working and after a lot of swapping of components I found that the logic board, TCON board and associated ribbon cables were healthy. The problem was the ribbon cables that go from a long slender PCB across the top of the panel onto the panel itself. The problem connection was on the PCB side not the glass panel side. These ribbon cables are attached with some kind of heat set adhesive.
            I'm aware that this type of problem usually isn't repairable...
            03-27-2020, 10:49 AM
          • viking509
            vizio e65 e3 LED tv color vertical lines center tv only
            by viking509
            I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
            03-21-2023, 12:48 AM
            HP EliteBook 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support Notebook 800 Specification for Upgrade or Repair
            This specification for the HP EliteBook 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support boardview and 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
            09-06-2024, 08:23 AM
