Vizio E320VA allegedly gets very loud and shuts down
  • Pioneerx01
    • Apr 2015
    • 241
    • US
    I go my hands on free Vizio E320VA. Previous owner stated that while watching TV, sound would get louder and then the TV would shut off by itself. I have no idea what they were watching on what input or for how long until this occurs.
    I have been "watching" the TV for several hours now and nothing happened. I have also removed batteries from the remote and covered up the IR port on TV just in case.
    If this was a real problem, what would be the most likely source of this problem? I am guessing power supply? Anyone has similar problem like this before?
    Thanks!
  • Agent24
    I see dead caps
    • Oct 2007
    • 5036
    • New Zealand
    Re: Vizio E320VA allegedly gets very loud and shuts down
    Hard to say. A stuck 'volume up' button makes sense, but then to shutdown afterwards? I don't know. Unless the code was then confused for power off command somehow.
    The PSU could be underrated or the capacitors are half-dead and the audio amp at full power is overloading it.
    I would not rule out faulty front panel buttons. I have replaced more front panel buttons than I ever expected to. The ones that use a resistor-ladder to create an analog voltage are most susceptible to faulty (dirty\high resistance) buttons. Multiplexed buttons are much more reliable.
    -David VanHorn
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • SS454
      vizio e650i-a2 backlight flashes then turns off
      by SS454
      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
      panel: au optronics T650HVN05.4
      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
      https://www.shopjimmy.com/vizio-56-0...-power-supply/
      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
      08-20-2020, 03:57 PM
    • mrtek
      Vizio M65-C1
      by mrtek
      Hi.
      picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
      When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
      This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
      07-14-2025, 07:28 PM
    • howardc64
      Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
      by howardc64
      Failure Symptom
      No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
      Where is the short?
      Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
      Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
      05-27-2025, 02:56 PM
    • aidanmo
      Philips 43PUS7506/12 - Loud blown out sound
      by aidanmo
      I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
      I thought maybe the speakers got damaged, so I replaced them - no dice.
      • Using the internal speakers, it always happens.
      • Using the headphone jack, it never happens.
      • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
      02-28-2025, 03:13 PM
