Olevia 237-S11 controls locking up losing sound etc etc
  • Taterbug
    • Dec 2013
    • 114
    I am working on an Olivia 237-S11 and it plays a few minutes then it loses sound or screen locks up or just goes blank. I turn it off and right back on and it starts working for a while. I have replace the 1000mfd and 680mfd caps on the power supply board. Has anyone else experienced this problem and found a fix for it?
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Olevia 237-S11 controls locking up losing sound etc etc
    Sounds like an IC fault on the motherboard.
    Pics?
    • Taterbug
      • Dec 2013
      • 114
      I took the mother board out and examined it. Everything looked good on it. Upon looking at the power supply again with a magnifying glass I noticed the solder joints on the connectors were horrible. I re soldered all the connections and now it plays for about an hour and the screen goes black and the blue light comes on. I can turn it off with the remote and turn it right back on and it works. Now I'm wondering if I have an intermittent problem with the inverter board I have not taken it out and checked the caps on it yet I will also post pictures the next time I take it apart???
      • Taterbug
        • Dec 2013
        • 114
        Ok still working on problem. When unit is shutting down and I'm getting blue light in losing voltages on ps. I examined both inverter boards and saw no sign of arching or bad caps and solder joints looked good. I don't want to get into the buying boards without knowing exactly what is going on. Anyone have any suggestions??? Actually what I just did was unplug the X and Y inverter boards and am going to let it play with the backlight disabled and see if it could possibly be an arching or bad lamp problem.
        • Taterbug
          • Dec 2013
          • 114
          Power Supply still shuts down after playing about 30 minutes with both inverter boards unplugged. I am gonna replace the rest of the caps on the Power Supply Board. I checked a small 1 mfd cap with my capacitance meter and the ESR read 54 ohms. That seems high to me.
          • Taterbug
            • Dec 2013
            • 114
            Power supply not going out now. It freezes up now and have to cycle power. I have replaced all caps on power supply and bridge rectifier. I have also replaced the caps going to power on the main board. Anyone got any more suggestions??? It play's about an hour and screen freezes .. Remote won't work. Is it hard to reload Firmware and is it even available for 237-S11???
            • newtothis
              • Mar 2013
              • 1556
              • england
              I have no experience with these sets at all.
              Sounds to me like a thermal issue on an IC, Tried heating/cooling main?
              • Taterbug
                • Dec 2013
                • 114
                Just put fan on it to cool down power supply. Still playing. It was getting hot.
                • Taterbug
                  • Dec 2013
                  • 114
                  If that's the problem I've got to figure out how to cool it down or figure out what's causing the over heating problem.
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    So its running for longer under cooling?
                    So should fail quicker under heat, Use a hairdryer to narrow down the area that is failing.
                    • Taterbug
                      • Dec 2013
                      • 114
                      Actually it failed again right after I posted about using the fan. It just freezes up or screen goes white the have to toggle power and it will play one or two hours sometimes the freezes back up. Remote does not work or buttons on tv when it freezes up.
                      • Taterbug
                        • Dec 2013
                        • 114
                        Finally Fixed it !!! It was a bad cap on main board. 1000 mfd 35 volt. Jackson. ( see photos for location I replaced it with the big blue cap.
                        • Taterbug
                          • Dec 2013
                          • 114
                          Here is what I replaced it with and location on board
                          • newtothis
                            • Mar 2013
                            • 1556
                            • england
                            Is the top bulged on that cap?
                            • Taterbug
                              • Dec 2013
                              • 114
                              No , it was a nightmare to fix. I replaced EVERY cap in the power supply. It kept acting like a cap problem so I went for that one since it was tied to the microprocessor.
                              • newtothis
                                • Mar 2013
                                • 1556
                                • england
                                Good job on getting it working
                                • Taterbug
                                  • Dec 2013
                                  • 114
                                  • LEECH666
                                    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                    by LEECH666
                                    Good day ladies and gentleman!
                                    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                    01-19-2024, 05:46 PM
                                  • Christos Tsiligiannis
                                    Marian Trace Alpha sound card repair help
                                    by Christos Tsiligiannis
                                    Hello to the forum.
                                    My name is Christos, I am new to the forum here and i am posting from Greece.
                                    So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                    To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                    So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                    11-18-2024, 05:26 AM
                                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                    This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-12-2024, 02:30 PM
                                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
