toshiba 40l1333b lcd tv
    hi,
    I'm currently working on a toshiba 40l1333b tv with a display problem,
    it switches on fine and displays fine , but after a random time (could be 30mins could be 1 min) the display shuts down and i get sound but no picture.
    tested the power board and thats fine, the display shows absolutly nothing.
    im thinking it could be a fault on the main board or the inverter but im unsure.
    any help would be great.
    thanks
    david
    Re: toshiba 40l1333b lcd tv
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
      hi
      i currently dont have pictures as it is in another location, i might be able to get the today.
        This problem is due to the connections inside the LED backlight failing. It is repairable, but it is very difficult to do so.
          You are going to have to dismantle the whole lcd panel.
          Then the bridge the connections between the led strips with wire.
          The problem is the connections between the connectors from the sound of it.
          If you have dimming occuring anywhere on the screen before this happens then you need to replace the led strip as well...
          Please see here
          https://www.badcaps.net/forum/showpo...6&postcount=27
          Its a tedious job getting to them ...
            https://www.badcaps.net/forum/showthread.php?t=43379
              thanks all for getting back to me, it looks like one hell of a job to get it back up and working
                Yes, another piece of VESTEL junk sold as a Toshiba - no better than any supermarket junker, yet £60 more expensive!
                  Quite funny
                  that if you break the tv for parts..
                  its nearly worth more than the tv whole
                  that made me feel better with one with a failed panel a while ago
                    but if you set aside an afternoon and get a helper its doable.
                    awkward to do
                    but nothing hard to do to be honest.
