lg 50pc1da plasma fault
  • vnalocke
    • Apr 2015
    • 4
    • england
    hi from the information on this forum i believe i have narrowed down my issue to the ysus board but just wanted to check if anyone had any other thoughts.
    i have a flashing screen with a ticking noise from the ysus and the heatsinks remain cold, checked power board and all outputs correct , if i disconnect the xsus the screen goes black which suggests to me it is doing something and also the heatsinks are getting warm, the y buffers appear to be working again because they get warm and as i disconnect each 1 i loose that half of the screen, the only thing making me question this conclusion is that i cannot get the menu or inputs to show up on the screen either with the remote or the buttons on the t v is this also consistent with just a ysus issue.
    many thanks in anticipation
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: lg 50pc1da plasma fault
    Sounds like the usual ERC IPM failure on the (Probably) the Y-SUS board.
    Z-SUS has the same IPM and can also fail with exactly the same symptoms, Ive found that the Z-SUS ERC IPM fails probably more than the Y-SUS one for some odd reason...
    Menus not showing maybe just due to the very poor image with failed/intermittent IPM or could be a separate fault. Is there sound and a picture behind the image flashing--usually is faded pinkish image with ERC IPM int failure....
    TELEFIX
    • vnalocke
      • Apr 2015
      • 4
      • england
      Hi thanks for your reply the only sound I've had is static though not consistently with regards an image I cannot see one but as I cannot get up the menu I cannot set the input although if I just press the program up and down the flashing appears to vary in brightness as if the screen may be changing.
      With regards the zsus as I mentioned the heat sinks both warm up and if the zsus is unplugged I don't even get a flashing screen
      • mmartell
        • Oct 2013
        • 3189
        Use an empty toilet paper or paper towel tube to listen to which ysus ipm is making the ticking. It needs to be replaced.
        • vnalocke
          • Apr 2015
          • 4
          • england
          Thanks for the replies sorry for tardy reply but been away having difficulty de soldering the ipms so going to buy a ysus if I can find 1 at a reasonable price
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            They are a bugger to change. Ive got one here--been here about 3 months, even got the IPM's but keep putting it off....
            Sometimes its easier to use a fine side-cutters and cut its legs off close to the IPM case.
            Then de-solder the pin stumps one at a time, and clean out the through-hole tinned print.
            --Take care of the pressure you put on the print its not all that strong, and some connections to the IPM are on top print layer only.
            Another way is to use a hot-air paint-stripper to heat the heatsink up good and hot Then use the iron to de-solder the pins--You need a good temp reg 60W Iron to do it, with both braid and sucker to do the job....
            Another way is to make a 'jig' from some scrap copper bar approx same length as IPM, cut a slot in it and heat that, tin it up and apply that to the row of pins, let the heat soak through and carefully lift one side at a time....
            --Been meaning to try this one out, but I think I would modify the idea and adapt a small low power hobbyist blow-torch to heat the copper continuously, That print and IPM suck heat like you wouldnt believe!
            TELEFIX
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • Alicat
              Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
              by Alicat
              Stopped by this site trying to fix my parents Panasonic Plasma TV.
              Model number is TH-50PZ85U
              Power comes on and the red power light stays on solid.
              Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
              I also hear a few clicks.
              I also think my parents said there was a thunderstorm and the TV failed after that.
              Section 6 in the service manual talks about power and no screen,...
              10-30-2024, 10:09 AM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
            • Zelek11
              Panasonic Plasma screen interference on left half of screen
              by Zelek11
              My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
              This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
              10-14-2022, 04:54 PM
