LG 50PJ550 YSUS & ZSUS Component part numbers
  • simplytrini
    • Jul 2011
    • 73
    Hi all, I am wondering if anyone can help me with a problem? A customer brought in an LG Tv 50PJ550 for repair, after inspection of the TV I realized that the TV had been worked on by someone else and found that a few FETS are missing from the Ysustain and Zsustain boards. Can anyone help me identify the part numbers?
    Ysustain: EBR63039802
    Part Locations: Q02,Q03,Q22,Q24
    Zsustain:EBR63040301
    Part Locations: Q21,Q22,Q23,Q24
    If anyone can tell me the part numbers, that would be awesome! Thanks in advance.
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: LG 50PJ550 YSUS & ZSUS Component part numbers
    sure give me 24 hrs or less
    • simplytrini
      • Jul 2011
      • 73
      Thank you!!
      • simplytrini
        • Jul 2011
        • 73
        Any help with would realy be appreciated! Thank you!!!
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Well--The 42" version (Which looks Very similar to the one pictured) uses 30J124 and 30F124 for the 'SUS_Up and SUS_Dn' IGBTS (That always seem to fail in this series)--Although I cant remember which is which offhand and haven't any data/diagrams.....
          I expect that the 50" uses much the same--but with an additional one in parallel, so three for each function (There's a place on the 42" version for the additional IGBT)....
          Dunno what ones your schematic ref numbers refer to though.....
          TELEFIX
          • Hamie
            • Apr 2014
            • 1383
            I know all parts but can't remember what order they go.
            They will be 51N25, 30F124 and RJP63F3
            Also worth checking all the RD2003 diodes. Replacing both ceramic caps located on the ysus. Think they are 102j
            • simplytrini
              • Jul 2011
              • 73
              This is great! thanks Alastair E and Hamie. Your help is very much appreciated.
              • simplytrini
                • Jul 2011
                • 73
                Hamie, do you know the orentation or these components according to the positions numbers on the boards
                eg :
                Q21-
                Q22-
                etc
                in really don`t want to make things worse, so again your help would be appreciated. Thank you!!
                • Hamie
                  • Apr 2014
                  • 1383
                  eg :
                  Q21-
                  Q22-
                  etc
                  Sorry I was on holiday hence why I couldn't remember what order they went in.
                  I'm back now and can provide all the part number and order if
                  You still require them.
                  • simplytrini
                    • Jul 2011
                    • 73
                    Hi Hamie, If you can provide that info it would be awesome. Thanks again!!
                    • simplytrini
                      • Jul 2011
                      • 73
                      HI ALL, DOES ANYONE HAVE THIS YSUSTAIN BOARD(EBR63039802)ON HAND OR KNOW THE THE ORIENTATION OF THE COMPONENTS Q02,Q03,Q22,Q24?
                      I KNOW THE PART NUMBERS (51N25, 30F124 and RJP63F3) BUT I DO NOT KNOW WHAT ORDER THEY GO IN. ANY HELP WOULD BE MUCH APPRECIATED. THANK YOU!!!
                      • RADIOTRON
                        • Aug 2011
                        • 7
                        Q22,24 = RJP63f3
                        Q26,28 = FDPF51n25
                        Q02,03 = 30f124
                        • Jeff Pepin
                          • Jun 2014
                          • 103
                          • CANADA
                          Originally posted by RADIOTRON
                          Q22,24 = RJP63f3
                          Q26,28 = FDPF51n25
                          Q02,03 = 30f124
                          Thanks a lot this info help me right now !!
                          • godkain
                            • Jan 2020
                            • México
                            Thank you for your help, I would like to know if anyone has the information of q21 because they already said of q22 and q 24, I hope you can help me
                            • edugimeno
                              Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                              by edugimeno
                              Hi There!
                              I'm trying to help my friend who owns a restaurant be just bought.
                              He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                              It's stuck using, I guess, the 2 sided tape that comes with the strip
                              The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                              09-05-2024, 09:34 AM
                            • G-Sting
                              iPad Pro A1876 SHORT Part Identify Help Needed
                              by G-Sting
                              So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                              So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                              i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                              SO My main concern is what part should i order what should i search the name for ?
                              on Ipad...
                              05-15-2025, 09:30 AM
                            • PlasMatt
                              LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                              by PlasMatt
                              I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                              09-20-2025, 06:50 PM
                            • FreakyMex
                              Trouble to identify part (Lunii screen) for replacement
                              by FreakyMex
                              Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                              I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                              02-17-2025, 01:16 AM
