Magnavox 42MF531D/37 has high pitched whine coming from speakers after repair
  • SurrealMustard
    • Jan 2015
    • 487
    • The United States of America
    With the help of the community, I recently repaired my no-power Magnavox 42MF531D/37 LCD television (replaced capacitors and diodes on the power supply and then replaced the mainboard twice). It now powers up and runs how it's supposed to, but I've noticed a high pitched whine that comes out of the speakers. It happens on every input and at every level of volume (except mute). The best way to describe it would be to imagine a room with 5-10 standard definition CRT televisions all running with their sound turned off.
    The noise usually comes on right away when the television is turned on, but if it doesn't, it begins after the set has been on for an hour or two. It has the same pitch and intensity regardless of what is playing. Relief only occurs in the brief period of switching inputs, when the sound is muted, or when the volume is turned all the way down.
    I hooked up a pair of headphones to the headphone jack to see if the problem happened in there too, but it does not. Only out of the main speakers.
    Anyone have any troubleshooting tips or know of what might be causing this?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5084
    • New Zealand
    Re: Magnavox 42MF531D/37 has high pitched whine coming from speakers after repair
    Sounds like something wrong in the amplifier section, picking up interference or just gone bad.
    If the headphone jack doesn't have the problem, trace the audio signal from there to the speakers and find where the noise appears, then you should be able to narrow down what its causing it.
    -David VanHorn
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      May be a bad solder joint to a shield ground.
        I've had a similar issue (whining after some time running) caused by a bad cap on the CPU voltage rail. Wasn't bulging but 16 ohm ESR and something like 300mVp-p on an 1.8V rail, way too high. Since your fault is intermittent, I'd get out a can of freezer spray and a hot air gun/hairdryer, and see if you can narrow down the source of the fault.
        • SurrealMustard
          • Jan 2015
          • 487
          idea
          Can that be done with just a dryer and hot air gun if I don't have any freezer spray?
          • Agent24
            I see dead caps
            • Oct 2007
            • 5084
            • New Zealand
            You can use the hot air to heat things but then you have to wait a long time for them to cool down again. The problem is if you heat more than one thing at once you don't know which one fixed the problem. It is easier to selectively cool things than it is to heat them.
            -David VanHorn
            • SurrealMustard
              • Jan 2015
              • 487
              Happy ending
              This one ended up being a stumper for me, but I'm calling it a partial win because the core functionality was restored. I ended up selling it as-is for a (small) profit to someone who was going to be using external speakers and a wall mount with it.
              In the future, I'll be better equipped to handle these types of repairs with my new capacitor tester that I picked up while working on the RCA DLP. Looking back, each of these repairs has made me a better technician. Apparently, there's no replacement for practice .
              • tonybig10
                Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                by tonybig10
                Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                03-07-2025, 01:03 PM
              • Gjackson
                ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
                by Gjackson
                Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
                01-13-2024, 10:34 AM
              • 90Ninety
                Coil Whine , buzzing, identifying parts R9 Fury
                by 90Ninety
                I have an R9 Furty Nano ( R9 2XX IIRC ) that I want to put to use , I got it on ebay for quite cheap but, it has some of the worse coil whine I have heard .
                I tried putting a long tube on my ear and hovered it around the card while in use , I cannot pinpoint it . However I my educated guess is , that it the whine is an inductor coil and it is one or all of these in the picture . Does anyone know what part this is and what part I can replace them with .
                Perhaps likely is that I am missing something else it could be , here is a stock picture...
                12-15-2022, 04:18 AM
              • Kartowl
                philips 47pfl6158k/12 image faded away, sound still coming from TV
                by Kartowl
                Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                04-23-2024, 12:57 AM
              • abefroman
                Magnavox MDR515H HDD DVD Recorder Whine
                by abefroman
                I have a Magnavox MDR515H HDD DVD Recorder that has a high pitched whine when plugged in and will not turn on. I opened the unit up and saw 3 3300uf caps on the power supply board and 2 1000uf caps on the mainboard that were bad. I replaced the 5 caps and the whine is still there and no power. Has anyone else had this issue?
                08-29-2020, 12:03 AM
