Philips 47PFL5603D/10, loses picture after about 50 minutes
  • Nicholas
    • 60
    • Kingdom of Denmark
    Hi guys.
    I have this Philips 47pfl5603d/10 LCD TV that loses the image after about
    50-60 minutes. Sound is still there only image goes away.
    I just opened the set, all caps on the PSU *looks* okay. I just wanted
    to hear if anybody else has come across the problem before?
    Thanks,
    Nicholas
  • Hamie
    • Apr 2014
    • 1383
    Re: Philips 47PFL5603D/10, loses picture after about 50 minutes
    is the backlight still on when the picture disappears?
    • Nicholas
      • 60
      Hamie, it seems that the backlight is on, and only the image on the panel goes away.
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Worth monitoring the voltage supply to the T-Con board....
        Does the sound remain OK?
        TELEFIX
        • Nicholas
          • 60
          Hi, yes the sound is still present! Also, menus are gone as well,
          so complete image loss.
          I can see the T-Con board only has one cable running to it (attached picture)
          from the main board. Could this still be PSU-related, or maybe main board?
          Thanks,
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Dunno--Check the voltage on the fuse of the T-Con when fault present--That will tell you whats what....
            Voltage OK--Check LVDS signals with scope....
            TELEFIX
            • Nicholas
              • 60
              Hi again.
              I ordered a new T-Con board, and that seem to have fixed the problem.
              However, the new board wasn't 100% the same version number etc. as
              the older one....so now I have a strange problem Hard to describe, but
              some lines has extra lines. Please see my attached pictures. There are vertical lines
              between the letters for instance. The video image looks, well, like high res
              scaled down to 150 lines or something like that.
              Any idea if this is fixable without getting yet another T-Con board?
              Thanks!
              Nicholas
              • jetadm123
                • 2169
                Have you tried re-seating the t-con cables? Post a photo of the old and new t-con boards.
                • Rauni
                  Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                  by Rauni
                  Hello, this is my first post on this forum, and my first attempted to repair a TV.
                  My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                  Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                  Read also that we should test what happens if we...
                  10-01-2023, 12:06 AM
                • Schwoin
                  Philips 243v5lhsb00 Monitor Picture too bright
                  by Schwoin
                  Hey everyone,
                  the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                  While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                  you can see them on the top half of the photo.
                  At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                  03-21-2023, 12:40 PM
                • madyoyo
                  Philips 37pfl560: Yellow picture
                  by madyoyo
                  HI.
                  I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
                  Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
                  05-30-2025, 10:16 AM
                • charlesdutcher
                  No picture issue in Philips Chassis FTL2.1
                  by charlesdutcher
                  My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
                  Is there someone having any symptom like this? How to fix it?
                  Thanks in advance!​
                  08-06-2024, 09:55 PM
                • groomit
                  Philips 50PUS7363/12 Backlight but no picture
                  by groomit
                  I'm having trouble with above mentioned TV. Bought it defect.
                  Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
                  Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
                  I can see backlight, but screen stays black.
                  What I've tried:
                  - Disconnect right side cable from T-Con -> same (backlight but no pic)
                  - Disconnect left side...
                  11-22-2024, 02:43 PM
