Philips 47pfl5704d/f7, (1) long & (4)short blinks
  • kmab
    • Mar 2015
    • 16
    • usa
    Hi Guys,
    Philips 47pfl5704d/f7 no picture, no sound, stnby light one long and four short blinks... Visual of power supply looked OK.. Any ideas... Also need service manual... thanks Joe
  • habanerocat
    • Nov 2014
    • 96
    • Ireland
    Re: Philips 47pfl5704d/f7, (1) long & (4)short blinks
    you'll need to post the chassis no.
    • kmab
      • Mar 2015
      • 16
      • usa
      chassis no pl9.1
      please refer to my other thread "Philips 47pfl5704d/f7 added pictures"
      thanks for the reply
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        I think one thread is enough for that TV.
        • kmab
          • Mar 2015
          • 16
          • usa
          agree - how do i delete this thread....
          • Tom_x
            HP Omen 15-dc0001nh capslock blinks 5 long and 3 short
            by Tom_x
            I have HP Omen 15-dc0001nh (DA0G3DMBCE0 rev: E) with blinking capslock 5 long and 3 short. Fans spin constans speed.
            HP worked for 2 months after i repaired (before damaged by thunder via rj45 port) I removed LAN ic and powered on
            Now with blinking capslock:
            All voltage present on big coils, except +VCCGT (i don't know this need for booting)
            I tried re-flash bios with known firmware- same result (now i don't have spare bios chip to test spi flash failure)
            DDR4 ram is ok, tested on other laptop
            WLAN and SSD removed,...
            07-20-2023, 10:10 PM
          • Biruslapio
            Panasonic P58V11B 8 and 12 blinks error "fix"
            by Biruslapio
            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
            04-13-2021, 07:13 AM
          • jimbofz
            philips 55 oled 745 /12 3 blinks
            by jimbofz
            Hi this tv was fine until the owner moved to another address,
            it comes on in sby with 3 blinks and psu wont start up .
            tried a power on reset by holding down power on button on rear of tv and applying mains no luck
            first inspected for damage dry joints or loose foils no joy
            checked psu volts ,the 12v and 24v supplies should be switched on by the main board no volts
            i read on the net that the micro on some later philips may need a reflow ,removed psu checked all caps with esr meter all ok
            removed main board
            and heatsink on micro
            heated...
            02-15-2021, 05:49 AM
          • Chandaj
            hp 15-bw014la - 5 long 3 short caps blinks.
            by Chandaj
            Kindly help how to resolve this issue
            I have programmed BIOS and EC chips still same problem, fun is spinning fast
            hp 15-bw014la CTL51/53 LA-E841P rev 2.0
            03-02-2023, 04:01 AM
          • Sharpa
            Repair attempt Philips 55OLED804/12
            by Sharpa
            I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
            The symptoms when bought: Philips logo appears then tv turns off
            Things tried so far:
            1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
            2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
            Yesterday, 08:30 AM
