Lg 50pk590
  • Hamie
    • Apr 2014
    • 1383
    Re: Lg 50pk590
    Originally posted by diif
    I bought a replacement part IC301. It was the only part in the repair kits i hadn't tested as i was unsure how.
    No that's on the power supply.
    I need to stress you have do not have a problem with your power supply.
    That kit is for for "the tv clicks on then goes back to standby'
    You have a constant vs and constant va, and permanent panel glow.
    The power supply and ysus are performing as expected.
    You have either a faulty control board or a faulty mainboard.
    I'm fairly confident if you replace the mainboard your tv will work again.
    • diif
      • Feb 2014
      • 6978
      • England
      #42
      Re: Lg 50pk590
      Ah, i understand now Hamie, thanks, i shall look to source a new mainboard.
      • Hamie
        • Apr 2014
        • 1383
        Re: Lg 50pk590
        If you can't find one for the 50pk590.
        The 50pk350 might share the same boards.
        • diif
          • Feb 2014
          • 6978
          • England
          #44
          Re: Lg 50pk590
          Can you shed any light on the LED flashing differently on the control board ?
          Should i put the other IC back ?
            Re: Lg 50pk590
            I believe it's a temperature indication - I'm not certain it's a fault code. I remember reading somewhere in an LG manual.
            • diif
              • Feb 2014
              • 6978
              • England
              #46
              Re: Lg 50pk590
              Thanks guys, when looking for a replacement is it the EAX61141604 number i use ?
                Re: Lg 50pk590
                EAX = Assembly number, whole board w/ exact parts
                EBR = Board number, blank PCB with possibly many options
                Use EAX over EBR
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #48
                  Re: Lg 50pk590
                  Thanks Tom, seems they are quite scarce.
                  • Hamie
                    • Apr 2014
                    • 1383
                    Re: Lg 50pk590
                    Just thought I'd update this, I recently repaired a 50PK350. Whilst repairing it I noticed that someone was selling a 50PK590 with a faulty panel, I bought it to see if you can easily upgrade and downgrade this TV with the mainboard swapped.
                    You can, and the back cover of the 50pk590 also fits perfectly on the pk350 front.
                    if you don't have a broken screen you would have to make some modifications to the back cover if you are forced to 'downgrade' to the 350.
                    Just though I'd post this incase anyone struggles to get a mainboard for the 590 and just wants a working TV, As the 350 mainboard are more common.
                    Or if you have a 350 and want to upgrade it so that it has 4 HDMI and 2 USB along with HD freeview and internet access. Keep you eyes peeled for a faulty/broken 590.
                    • sordids999
                      • May 2013
                      • 2149
                      • uk
                      #50
                      Re: Lg 50pk590
                      hello
                      im struggling with a different fault sound but no picture
                      VS 202 volts VA 59 volts also Zbias is good
                      but -vy = -18 volts vsc = 19 volts on the Ysus
                      what i have done so far
                      1.Removed buffers voltages still the same
                      2.Removed Zsus from power supply still no change
                      3.Checked the three 10 ohm resistors on power supply all readings good
                      4. Tried jumping control board with main board disconnected but nothing
                      any ideas
                      • Hamie
                        • Apr 2014
                        • 1383
                        Re: Lg 50pk590
                        You have a faulty y-sus.
                        Usually checking the heatsinks for shorts would be a good place to start.
                        But considering that you can buy a replacement y-sus for £14 on eBay it's probably easier quicker and even possibly cheaper just to change out the board.
                        • sordids999
                          • May 2013
                          • 2149
                          • uk
                          #52
                          Re: Lg 50pk590
                          Thanks hamie ill update soon how i get on
                          • sordids999
                            • May 2013
                            • 2149
                            • uk
                            #53
                            Re: Lg 50pk590
                            Ysus replaced all working again
                            • newtonuk
                              • Jun 2017
                              • United Kingdon
                              #54
                              Re: Lg 50pk590
                              Hi, sorry to resurrect an old thread, but my 50PK590 just started doing this. The set turns on, the screen glows, but it won't show any picture including menus etc.
                              I'm not very electrical, but would appreciate your help. I've also found this service on eBay which seems promising...
                              http://www.ebay.co.uk/itm/Repair-Ser...8AAOSw~y9ZHJch
                              • Noah Glasse
                                LG 50PK590 - three clicks and steady red light, won't turn on.
                                by Noah Glasse
                                I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
                                I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
                                02-24-2025, 07:23 AM
                              • tvguy12012012120
                                by tvguy12012012120
                                02-07-2025, 05:13 PM
                              • fharris1977
                                Vizio D50u-D1 Dead Set No Standby
                                by fharris1977
                                Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                12-28-2023, 10:25 AM
                              • Crystaleyes
                                Samsung BN44-00259A standby question
                                by Crystaleyes
                                Hi all.
                                I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                08-11-2023, 05:15 AM
                              • goldbird78
                                LG 50PK550 EAX61392501/10 EAY60968801 clicks and shuts off immediately
                                by goldbird78
                                Hi All, I have an LG 50PK550 with the EAX61392501/10 EAY60968801 power supply board. When I turn it on it clicks and shuts off immediately, I have unpluged the power wires to to Zsus and Ysus board and it does the same thing. I have read up and replaced IC301 & d304 and checked the R927 R929 and all 3 fuses on the board and all appear ok. Still does the same, shuts off immediately with or without the z & ysus board hooked up. Any help would be appreciated. Thx
                                02-17-2021, 08:45 PM
