Kdl-55hx800 4 blink, no picure or sound
  • milkman6453
    HVAC
    • Mar 2015
    • 39
    • usa
    Re: Kdl-55hx800 4 blink, no picure or sound
    did you apply pressure while the set was on or off? If on, what was the result? Flicker then dark spot vanishes?
    • Tom.molyn
      • Mar 2015
      • 16
      Yes, i tested it with the screen on, i would press them down and they would turn on, if i alternated ribbons it would result in a flicker i suppose.
      • henryvrensburg
        • Oct 2018
        • 104
        Hi guys
        I got the same set from a friend with exact same symptoms as Tom.molyn described
        "The tv would power cycle initially.(no picture or sound)
        I was able to get 3.3v on the standby voltage at all times.
        The on power and high voltage would be on for the first 2 seconds inbetween "clicks"
        I replaced the BAL board and the same issue happened.
        I was able to keep the power from cycling when the T-con board was disconnected from the Inverter.
        I replaced the LED Driver board as well as the T-CON. When I replaced the LED Driver board, symptoms were still the same.(4 x flashes, no display, clicking sound) When I replaced the T-CON, the set now comes on with white screen, I can see the set tries to respond to the remote, but no display. If I remove one of he TABS from the T-CON to the Panel, both sides come on as white, although one side is whiter than the other side. I also replaced the BAL board, with no luck.
        I do have sound, backlights and a white screen.
        DO you think I got a bad T-CON board from my supplier?
        Thank you for reading this, and any subsequent help.
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
        • Christos Tsiligiannis
          Marian Trace Alpha sound card repair help
          by Christos Tsiligiannis
          Hello to the forum.
          My name is Christos, I am new to the forum here and i am posting from Greece.
          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
          So i tried asking for a schematic from the company and they would not give me one. Instead they...
          11-18-2024, 05:26 AM
          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
          09-12-2024, 02:30 PM
          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
