Sharp lc-42sb45u power issue
  • carltonfire176
    • Mar 2015
    • 19
    Ok. I was recently given a broken television for a project. It is a 42" Sharp lc-42sb45u. The guy who gave it to me said the tv would work for a little while and randomly shut itself down. After I picked it up and got it home, I plugged it in to test it. When I plugged it in and tried to turn it on, nothing happened.
    I checked the cord, and the connection to the tv and the wall. What should I do next?
    Re: Sharp lc-42sb45u power issue
    Do you have a digital multimeter, and a camera?
    • carltonfire176
      • Mar 2015
      • 19
      I'm pretty sure I have one out in my toolbox, and as far as a camera goes I have one on my phone (galaxy s5)
        OK could you remove the back cover of the TV and get us some clear photos of all of the boards inside the set. I use an S4 to take my photos so the S5 should be at least as good. Just make sure to get them in focus. A photo of your meter will also help.
        • carltonfire176
          • Mar 2015
          • 19
          sorry for the delay. I got caught up between work and fire calls I havent had a chance to mess with it too much. Anyway heres the pictures.
          My Multimeter
          Main board
          Power Supply
          Controller Board?
          And lastly the board behind the buttons, not sure what its called
          I used my multimeter last night and tested the resistance across the fuse above the power port. It tested at 6.5 so im assuming the fuse is good.
          • jetadm123
            • 2169
            Your 3rd photo shows the power supply. Is that large capacitor closest to the upper right wiring harness domed?
            • carltonfire176
              • Mar 2015
              • 19
              If this is the right one i circled it is
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                Yup--thats the one--Will need replacement.
                Check closely all the others for doming too, replace those that look domed.....
                TELEFIX
                  One is already bad, you might as well replace them as a set including those on the inverter board (CMO).
                  • carltonfire176
                    • Mar 2015
                    • 19
                    thanks guys, ill look for the parts tonight. By replacing those, I should get power correct?
                    • carltonfire176
                      • Mar 2015
                      • 19
                      is this what I need?
                      http://www.ebay.com/itm/CAP-DIODE-RE...item3386fc0dd9
                      • carltonfire176
                        • Mar 2015
                        • 19
                        or this?
                        http://www.ebay.com/itm/CAPACITORS-p...07997657&rt=nc
                        • jetadm123
                          • 2169
                          Try this:
                          http://www.ebay.com/itm/Sharp-LC42SB...item4d06c815df
                          Be sure to compare the capacitor values in the listing to the ones that are actually on your board. If there are differences, notify the seller and see if they will substitute the correct value.
                            TBH I'd just get the caps from Digikey or if Topcat (site admin) stocks them, from badcaps.net store. It'll be cheaper and you'll be certain you're getting good, high quality replacements. If you need help choosing the right ones just ask.
                            • carltonfire176
                              • Mar 2015
                              • 19
                              tom66, can you point out which ones for me. to be honest i have no idea what im looking for.
                              • carltonfire176
                                • Mar 2015
                                • 19
                                I looked into them on the sites store. I have 2700uF 16volt caps on the board now but they are not listed in the master catalog.
                                • Alastair E
                                  Chief Womble
                                  • Mar 2013
                                  • 1963
                                  • U.K.
                                  Use 3300uF 16V will be fine, 2700uF isnt a hugely popular value.....
                                  --The slight higher value wont make any difference where they are...
                                  TELEFIX
                                  • carltonfire176
                                    • Mar 2015
                                    • 19
                                    okay! =) thank you. Also I noticed on the board that there are 4 capacitors but 1 of them is shorter than the other ones. Will that make a difference?
                                    • carltonfire176
                                      • Mar 2015
                                      • 19
                                      Also, 3300uF in a 16v are not listed on the sites store either. If i were to get them through digikey, which type would I need?
                                      • Alastair E
                                        Chief Womble
                                        • Mar 2013
                                        • 1963
                                        • U.K.
                                        Not really, just match the component values reasonably closely.
                                        TELEFIX
                                        • claws77
                                          lenovo flex 5 14itl05 power sequence issue
                                          by claws77
                                          hi guys, my motherboard will not start no matter what
                                          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                          but rest nothing happens no sign of life.
                                          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                          i have no knowledge of motherboards ....
                                          10-20-2024, 02:48 PM
                                        • yaya3gmax
                                          Laptop Power Issue – Works on Battery, Fails on Adapter Load
                                          by yaya3gmax
                                          Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                                          Symptoms:
                                          • Laptop works normally on a pre-charged battery.
                                          • Battery does not charge when adapter is connected.
                                          • Without battery:
                                            • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                                            • Speakers “pop” when power cut occurs indicating harsh sutdown.
                                            • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                                          08-21-2025, 07:16 AM
                                        • SuperJames
                                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                          by SuperJames
                                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                          Specs
                                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                          Backstory
                                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                          10-23-2023, 04:09 PM
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
                                        • bcstedt
                                          LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
                                          by bcstedt
                                          LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
                                          Problem:
                                          On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
                                          It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
                                          01-18-2024, 01:03 PM
