Lg 32LG3000 no picture
  • vili23
    • Sep 2014
    • 24
    • Croatia
    Hi!
    I got this tv from a guy who said that before the tv showed vertical lines but now there is nothing on the screen.
    When the tv turns on led flashes 2 times,backlight flashes and turns off.
    I checked the voltages on psu and they seem ok, caps look ok too.
    I tested the fuse on t-con and thats ok too. The inverter board gets 24v so I think that its ok too,but not sure,what do you think?
    How to check the main board? What would be my next steps in troubleshooting this tv?
    Thanx!
  • vili23
    • Sep 2014
    • 24
    • Croatia
    Re: Lg 32LG3000 no picture
    anybody?
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Backlight coming on?
      Any sound?
      TELEFIX
      • vili23
        • Sep 2014
        • 24
        • Croatia
        no sound
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          So--This is called, 2 sec to black...
          Search on this forum for '2 sec to black' and pointers on that fault, even on different make/models, the fault is very common....
          TELEFIX
          • ItepK
            LG 32LG3000 TV, three red light flashes, then the backlight turns on, but no picture
            by ItepK
            Hello everyone! I've found this television, and I began troubleshooting it.
            First, the television kept rapidly power cycling. I've warmed up the capacitors with a hairdryer, and after 3 dimmed red blinks, the backlight turned on, then turned dim, and no picture was present on the screen.
            I believed that this was caused by a bad power supply producing insufficent power (I've measured 3.5v on the 5.2v rail), so I've blindly recapped the board.
            After the recapping, all the voltages stableized, however, the issue in the title still remains.
            I could...
            01-03-2025, 09:01 AM
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Rmasters3
            55" Magnavox LED set flashes picture
            by Rmasters3
            When using a cable box with an HDMI connection, I turn the set on and a scene flashes on the display, but then goes to black. When I bring up the sets Menu, this will run for an hour as well as anything else. I have replaced the cable box with no effect. I'm getting ready to try a Blu-Ray player to see how that acts.
            Does anyone have thoughts? Thanks
            02-03-2023, 01:19 PM
