Tc-p50s30 code 14. Sc board short.
  • Camac
    • Mar 2015
    Hi. New guy here. Trying to repair Panasonic Tc-p50s30.
    Have had minimal experience with this type of repair.
    Have pinpointed short at sc board.
    Unable to find a new or refurbished board anywhere. Any help would be greatly appreciated.
    Sc board TNPA5351 AM
    THANKS TO ALL.
  • tw2005
    • Oct 2011
    • 6458
    Re: Tc-p50s30 code 14. Sc board short.
    if skilled with soldering and using multimeters, buy a kit and repair or send to moduslinkpts or a number of Ebay repairers now.
    could be as simple as replacing 4 x 30f131 transistors. there was a thread yesterday on the same tv and similar questions. have a look or try a search on the model or board number
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • duwane
      MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
      by duwane
      Hi All.
      I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
      Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
      After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
      Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
      10-17-2023, 07:48 PM
    • sfernandes
      Sega Dreamcast NTSC-U Revision 0 Launch Unit GD ROM PCB Board Short
      by sfernandes
      Symptom: When I press the power button the power LED lights up for a second and the fan etc spins for a second then the unit turns itself off and will not do the same thing again unless I unplug the power cable for a few minutes then plug it back in otherwise if I just turn the power switch off and back on right after it comes on for a second it will not come on again unless like I said unplug the power cord for a few minutes then plug it back in.
      What I have done to try to isolate the issue so far:
      The system powers on and stays on with...
      01-23-2023, 06:03 PM
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
