Proscan LED tv model # PLDEDE3992A Blue sceen only
  • mikecastillo
    • Feb 2015
    When turned on the screen displays multi color lines on the left side of screen then quickly fades to dark blue screen.
    Now, turns brighter blue screen with Dialogue box "no signal".
    Now, only dark blue screen.
    No sound or response from other control buttons on side of panel.
    There appears to be small droplets of oily residual substance on chassis panel between power and circuit boards.
    No scorch spots or areas of discoloration visible on boards, wiring or components .
    Used a known good X Box console to obtain video source. No reception displayed.
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • ulthi
    Samsung QE50Q60TAU - Flashes black/blue screen
    by ulthi
    My tv is not able to turn on. I flashes between black and vague blue screen (see video)
    I have tried different resets and have also replaced the main board - but nothin has changed.
    Any suggestions?
    https://youtu.be/acYQ-ImmhWA
    10-14-2025, 01:48 PM
  • gbbradshaw
    Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
    by gbbradshaw
    Hi.
    I have the Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 which has developed the following issue: blue screen while the sound it's still working. This happened after the screen developed some horizontal lines at first and then the next day suddenly turned into blue background. the screen was not damaged or anything. I can't access the menu. I have taken the tv to a local tech to have a look and he said that he thinks that it might be the pcb board as the back-lights are working and the sound aswell . I was hoping maybe you can guide me if I should buy the pcb board or not? Thanks
    02-22-2023, 01:31 AM
  • siuras676
    Dell XPS Plus 9320 blue screen and rebooting
    by siuras676
    I have a Dell XPS 9320 in for repair, and the machine has a strange issue.
    First, a bit of history: the laptop came in after liquid damage and was completely dead. I've repaired all the broken traces, replaced the damaged components, and it now powers on.
    However, it's now showing a Windows blue screen related to hardware (as seen in the picture), along with another Dell error I've never seen before.
    Has anyone encountered this issue on a Dell machine before and could point me in the right direction? I've checked the power rails around...
    04-07-2025, 12:10 PM
