LG 47LN5750/50LN5750 LED two seconds to black
  • JeffJ
    • Apr 2012
    • 189
    These tv's are exactly the same gut wise. So this is why i use both part numbers in the title.
    This seems to be pretty common these days. I read Alastair E's thread HERE about his issue. His test are terrific and had me barking up the right tree almost immediately.
    This tv is 13 months old, its a lemon or poor design or both, either way I had to order a new supply for this unit because there was no silk screening on the LED Driver chip at all, or maybe its burnt off. Or I would have replaced Just the chip to test.
    Here is the Supply for others reference LG EAY62810801
    Front:
    Back:
    The LED driver chip is the 24 pin SOP in the top left area of the back picture of the PSU. The replacement board i ordered had this chip on it as well, but guess what, it actually has something silk screened on it. Low and behold we have a part number. It's a BD9483F white LED Driver by ROHM Semiconductor.
    I will be putting the new board in tonight. I have 100% confidence it will fix the issue. But for any one else, replacing the LED Driver chip i described would probably do just as well, I will test this theory if i get my hands on a proper chip.
    I will post back my results for the purposes of others information. And i may order a 5 pack of these chips and replace it on the old supply so i have a spare for when this happens again.
  • JeffJ
    • Apr 2012
    • 189
    Re: LG 47LN5750/50LN5750 LED two seconds to black
    Well, I'll kick my self for not doing all of Alastair-E's tests and assuming that it was the exact same issue. I replaced the supply and the same issue. Bit the bullet, and took the panel out. Which i was trying to avoid doing at all costs. One strip of 4 of the 32 leds were bad. one is burnt.
    SO now i am hunting for a L1-TYPE 6916L-1176A, LED BACKLIGHT. I got 2 seconds of back light from all other strips and i moved a known working strip to the position of the burnt one and it lit in that position. so at least I know i only need this one strip.
    Too bad i couldnt just bypass this one bad led and get it going, I'd assume the diffuser would compensate enough for me to say screw it and run it 3 out of 4 leds on the strip.
    At this point id bark at LG for warranty if i didn't have it fully stripped on a work bench already. Boo-urns
    you live you learn eh?
    • newtothis
      • Mar 2013
      • 1556
      • england
      http://www.ebay.com/itm/LG-47LN5200-...-/121553808398
      • JeffJ
        • Apr 2012
        • 189
        First guy on ebay sent me a clearly bad LED strip, had one cut off and solder marks all over it. Looked like some amateur tried to rig it into working some how.
        However i got a led strip, installed it and all is well now.
        • robsmich
          • Nov 2015
          My LG 50LN5750 quit on me at 13 months as well.... now when you power it on, the LG logo flashes for less than a second and then it goes black. Same issue as yours? Where did you find a working LED strip? Thanks
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            You will need to take the panel apart to see if you do have a bad Led some where first.
            • Wizard76
              • Sep 2015
              • 5
              • usa
              Here is what I made work.
              Digi-key part#1416-1526-1-ND
              The solder pads underneath the are opposite than the samsung/LG
              cathode has larger heatsink on new ones I replaced so,
              I turned them according to the pads on pcb and then reversed the polarity at connector end.
              I could not tell any difference in the picture.Must replace all on that strip or rewire.
              • yasmiell
                • Feb 2016
                trying you LEDs now. I have a whole bad led strip. I hope I can fix it or get a new strip from ebay. Also I think my main board is faulty and I may have to order a new one.
                • chrismurphy
                  • May 2014
                  • 251
                  • australia
                  bypass the bad LED with 5 1n4004 diodes .
                  have done this many times and works with no noticeable image issues
                  Its not worth the issue to replace just one led
