Innolux Panels - reputation?
  • dkneyle
    • Dec 2013
    • 441
    I think I'm about to be offered an exchange on my dodgy 46 inch Kogan TV with a failed Samsung Panel (18 months it lasted with hardly any use). The TV they might offer me as an exchange says in the spec sheet that it uses an Innolux Panel. Anyone know the reputation of this brand?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Innolux Panels - reputation?
    Dont think 'Innolux' is a Panel Maker, Ive certainly never heard of it--More probably a name-tag the set maker attached to it, make the set look good in the specs....
    What Make is the set...?
    TELEFIX
      Innolux = Chi-Mei.
      Average reliability, poor picture quality. Generally cheapest of the bunch.
      I would ask for my money back.
      • dkneyle
        • Dec 2013
        • 441
        Mmmmm...that's what I feared! Out of interest then Tom, if you were in the market today looking to buy an off-the-shelf new LED LCD TV, what brand would you be looking at?
          Panasonic or LG only. (Sharp/Toshiba if >55" and definitely made by Sharp/Toshiba... they rebadge many 50" and below.)
          Avoid especially: Sony, Samsung, off-brand, etc.
          • eccerr0r
            Sell or Shim Solar panels?
            by eccerr0r
            Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
            However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
            So now what to do with these small panels?
            I could sell them...
            Or I could shim them....
            03-29-2025, 01:07 AM
          • hayriipek
            I need Innolux LCD M185BGE-L22 bios
            by hayriipek
            I need Innolux LCD M185BGE-L22 C3-G bios
            12-21-2024, 05:43 AM
          • TrueSword88
            KOGAN - KALED58RT9220SVA - Image flickering when in Energy Saving mode
            by TrueSword88
            Hi All
            I have a KOGAN 58' LCD Panel that 'flickers / pulsates' when in energy saving mode.
            I've reset the unit to factory default & rerun the initial setup but no change.
            IF I choose any other mode, example: Standard, flickering disappears.
            I've downloaded the most recent FW for this model from Kogan's website & re-flashed. This initiated a full wipe of the unit, which subsequently led to the setup all over again, however, the issue still remained - screen flickering but only when in 'energy saving' mode.
            I've taken the unit apart,...
            05-05-2023, 06:07 PM
          • NolesFan
            Can LED panels be used from different TV's ( or the internals to the panel )?
            by NolesFan
            I have a TV, ( example ) Sony XBR-75X80G that the LED panel is cracked, does anyone know if we can take the LED panel from a ( example ) Sony XBR-75X80H and plug it in and it will work? Or if the panel measurements is not exact, can we take the internals of the cracked panel 80G TV and mount into the good panel 80H TV? Thank you
            06-23-2025, 09:19 AM
          • japlytic
            Psuedo-4K LCD panels
            by japlytic
            I have come across (and was burned by at least one) so called "4K" (claiming 3840 * 2160) LCD panels which have an actual resolution of Full HD (1920 * 1080) meaning that every second pixel in either direction is skipped.
            For panels 19 inches (used in notebooks and tablets) and smaller with an Embedded DisplayPort (eDP) interface, do you know of any "4K" panels fitting into this category which do not have actual 4K resolution and the ones which have actual 4K resolution?
            12-31-2020, 06:15 PM
