Vestel Dvd Roms Need Help
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Hi all a friend of mine has lots of tvs ranging from 19"-26" they are all umc based logik brand, how ever they use a vestel dvd rom. The main issue is that at least 1 in 3 tvs the dvd player doesn't work at all, it wont even load the disk I have checked the board for dead shorts and nothing is obviously dead, if anyone has any experience with these junks please comment as we would like to get these players working and need help on where to check next. Any help is much appreciated thank you.
    The dvd rom model is 213052900 these can be purchased online but that would cause an instant profit loss so we would like to get the original ones up and running.
    Pictures showing the main board and dvd rom.
    • 31285
    Re: Vestel Dvd Roms Need Help
    have you got 5v and 12v at the dvd board?
    personally i throw he drives away.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Yes all the voltages are there we have tried new mainboards as well, im really beinging to think that one of the main controller chips is bad which is a shame because there are no replacements availble.
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Disconnect the disc motor and take a 9V battery.
        Put the batt The Wrong Way round on the motor--run for 15 seconds.
        Then reverse batt, and run for 15 secs again.
        Re-connect and it 'Should' work.
        TELEFIX
          • 31285
          the dvd is virtually stand-alone.
          if you have voltages, and it wont suck the disk in, check the switches that detect a disk and test the motor with a 9v battery.
          that's all i can think of.
          normally you can load & unload a disk wih nothing but power connected.
          the lasers dont last though - that's why i bin them.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Will do that now thanks.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Both the motors spin fine when I use a 9v battery, so that tells me they aren't being driven by the mainboard but thats where im stuck because everything tests fine and there are no shorts :L
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                I think that one of the main control chips is bad, not the mainboard as it works with other dvd players.
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  Right--Did you try them again After spinning the wrong-way with the battery?
                  The Object of the idea is to clean the motor's commutator as what happens is the motor is unable to spin up quick/fast enough to read TOC....
                  Cleaning the com with the batt trick--Usually--but not always restores operation.
                  TELEFIX
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Yes the tv doesnt even recognise the dvd rom any more its definatly somthing on the control board just dont know what I will try some more ticks tomorrow thanks for the reply.
                      Looks like one of the dreaded Chinese DVD ROMs. I don't think Vestel makes them. They would probably be better at it. Do you have any video output from it? Usually the output is CVBS so you can connect any old TV to it and get a video output, or see the output on a scope.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Its cheap I know that lol, on a good working drive the tv will show the dvd menu but one like this it doesn't even show that it just says no signal its driving (get the joke) me mad, I will have to take it to my uncles to be able to check it on a scope but where to start it the thing ?
                          Think if you just give it 12V (and maybe 5V as well, depends on the design) it'll just run and output video. That's my experience from other DVD drives. You can then look for something like a video signal on one of the pins, about 2Vp-p amplitude... if you uncle has ever repaired old CRT TVs he'll know what a CVBS (PAL/NTSC/etc) signal looks like
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            My uncle used to repair arcade machines but now does art work after an injury, I will ask him tomorrow and we will try that thank you Tom
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              I think that one of the chips that drives and powers the other processors has gone bad I will take a photo and highlight which chip I think is bad, in fact it even gets warm to the touch where as non of the others do meaning it could be possible shorted. I cant seem to find a replacement so I think that its scrap unfortunately.
                                Warm could be ok. It depends. Did you check for any video output?
                                  • 31285
                                  i'm confused.
                                  does it load the disk but not read it?
                                  because i thought it wouldnt load.
                                  if it loads the disk, and the disk twitches for a second then i will say the laser is weak and needs a tweek.
                                  the controller will power up the laser and look for a reflection to adjust the focus,
                                  if the beam is weak it will assume there is no disk and shutdown.
                                  the laser power ajustment is on the side of the laser assembly, there are 2 usually.
                                  one is for cd, the other for dvd.
                                  try putting an audio cd in the drive.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    It does nothing just plain nothing, the tv doesn't even recognise it as a dvd rom just dead. These tvs when they power up a good dvd drive will do that laser initiation noise but a bad one like the does nothing at all no initiation noise at all.
                                    Tom we hooked it upto the scope and got nothing, voltage is going into the chip that I think is defective but nothing is coming out when I get home I will take photos of the main processor chips and get back to you on the model numbers.
                                      • 31285
                                      3.3v regulator checked?
                                      oscilator running?
                                      • Jaime Morillo
                                        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                        by Jaime Morillo
                                        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                        The TV was stuck on the logo and I couldn't access the update menu.
                                        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                        The image result was good, but the image is inverted.
                                        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                        08-18-2025, 11:38 AM
                                      • France_53
                                        Vestel tv, how to flip the image?
                                        by France_53
                                        Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                        05-12-2024, 05:22 AM
                                      • FlailingEngineer
                                        Help with Bush Tv (Vestel 17mb95m Mainboard)
                                        by FlailingEngineer
                                        Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                        Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                        05-31-2023, 06:52 AM
                                      • lberkani
                                        Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
                                        by lberkani
                                        I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
                                        The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
                                        The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
                                        I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
                                        - Toshiba 65UL2163DG
                                        - Vestel 17MB180E mainboard
                                        - Panel VES650QNTX-N2-N42
                                        - Version V1.28.100.0 if available
                                        If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
                                        11-11-2025, 12:37 PM
                                      • hazi12
                                        Vestel main board 17MB140TC
                                        by hazi12
                                        Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
                                        Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
                                        I can send a dump....
                                        10-01-2025, 01:28 PM
