Panasonic TX37LZD800 died- Help!
  • Mikezoe
    • Feb 2015
    • 5
    • Uk
    I've had this excellent tv for 8 years and have just passed it on to my daughter when it's suddenly died (Embarassed look). On it's arrival in 2007 on the first day just after setting up it failed when I used the elongated switch on the bottom front left (as I recall there was a flicker on the screen then nothing and no standby light either). Then the shop took the set away and brought it back the same day and it has worked faultlessly every day since then but I never trusted that switch again and always used a wall switch thereafter! My daughter however did use the tv's switch and the problem has resurfaced. The first question is whether it is possible that the mechanical toggle switch has failed and if so how can I test this? Here are front and back pics of the power switch board. Can I, using just a small AA battery, a torchbulb and a couple of pieces of wire test the continuity of the switch contacts- seems there's 3 single poles. Maybe the switch isn't the issue and that on operating the switch the real failure occurred each time on another board? Any advice welcome!
    by sam_sam_sam
    After all of...
    07-13-2024, 08:14 PM
    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-06-2024, 05:30 AM
  • Natob82
    Micro Momentary Push Switch?
    by Natob82
    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
    12-21-2022, 05:22 AM
  • grimacelord
    NEC TurboExpress On/Off Power Switch Replacement Help
    by grimacelord
    I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
    I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
    I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
    11-09-2023, 09:49 AM
  • SluggerB
    Help making a switch work the opposite way with a relay
    by SluggerB
    I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
    I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
    It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
    02-07-2025, 07:57 PM
