PN50B430P2DXZA Sound Nothing Else Part Duex
  • Michale32086
    • Nov 2011
    • 1453
    Way way way back in Dec of 2014, I was working on a nice Sammy PN50...
    Being that I have learned a lot since then, I wanted to re-visit the unit and get confirmation on what I think is wrong..
    I am going to sum up the previous thread, but if anyone wants to refer back to it, it's here:
    https://www.badcaps.net/forum/showthread.php?t=42835
    What I have is a Samsung PN50B430P2DXZA. On plug-in/power-up, I get a relay click and I hear the Samsung startup tones..
    No picture on the display whatsoever...
    All voltages all check out per the label...
    The Control Board LED blinks the normal one-per-sec so it's not in protection mode.. But I replaced it anyways (got one cheep) but no luck..
    I get an audible power hum out of the X-Main board and a noticeable click-click-click-click (sounds like a BBQ Grill Igniter) from the Y-SUS board...
    Judging from the previous thread, my thinking is a bad Y-SUS board..
    Sound about right??
    Re: PN50B430P2DXZA Sound Nothing Else Part Duex
    If you can find Vsc and Vsch on the Y-main check if those are steady. Maybe worth checking buffer ICs... do you have a meter that beeps?
    • Michale32086
      • Nov 2011
      • 1453
      Yea, my meter beeps. I'll check Vsc and Vsch...
      Iffn ya don't hear from me in 10 mins, dial 911
      "If I'm not back in 5 minutes... Just wait longer"
      -Ace Ventura
      • Michale32086
        • Nov 2011
        • 1453
        Vsch is all over the place...
        Can't find Vsc, but there is a Vscan
        • Michale32086
          • Nov 2011
          • 1453
          If Vsc=Vscan, then it's also all over the place, but in the negative..
          • JamesTV
            • Nov 2014
            • 3
            If you've really learned alot then you should have learned how to read the label on the panel which should clearly state that VSC/VSCAN is a negative voltage. If it's not correct you will get either a blank screen or what would apear to be black clouds of missing pixels either in blocks, lines or both which is what I have with VSCAN at -44VDC. It should be on this particular panel -193VDC. I as a technician will attempt to fix this board but you as just learning more will probably fare better by replacing the Y-Main board. If you don't you'll probably do more damage than good. If you've fixed it then good work. If not them keep pluggin'.
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • LEECH666
              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
              by LEECH666
              Good day ladies and gentleman!
              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
              01-19-2024, 05:46 PM
            • PlasMatt
              LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
              by PlasMatt
              I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
              09-20-2025, 06:50 PM
            • Christos Tsiligiannis
              Marian Trace Alpha sound card repair help
              by Christos Tsiligiannis
              Hello to the forum.
              My name is Christos, I am new to the forum here and i am posting from Greece.
              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
              So i tried asking for a schematic from the company and they would not give me one. Instead they...
              11-18-2024, 05:26 AM
              HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
              This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:30 PM
