Samsung PN58A550S1FXZA turns on with audio chime, but doesn't completely turn on.
  • ALittlebit
    • Feb 2015
    • 51
    • United states
    Re: Samsung PN58A550S1FXZA turns on with audio chime, but doesn't completely turn on.
    Ok y-main and x-main disconnect stand by
    • ALittlebit
      • Feb 2015
      • 51
      • United states
      Exact same.
      • Shinju
        • Mar 2014
        • 1239
        Have you check all your fuses? This unit never comes on right?
        • ALittlebit
          • Feb 2015
          • 51
          • United states
          No it chimes up but never lights up. However the small light at the bottom of the screen stays on all the time while plugged in. How do I check the fuses?
          • ALittlebit
            • Feb 2015
            • 51
            • United states
            Just thought of something, the y-main while connected has a lot of low sound clicking however the x-main does not.
            • Shinju
              • Mar 2014
              • 1239
              Do this, reconnect everything again, hook up a source to HDMI 1 with a something playing like a DVd/Bluray or a music CD and see if you get audio.
              Edit:
              If your Ysus is clicking check your buffers. Thats how I found out I had a bad one was it was blown out the back of the board and drawing the Ysus down.
              • ALittlebit
                • Feb 2015
                • 51
                • United states
                #27
                Totally has sound pal!
                • ALittlebit
                  • Feb 2015
                  • 51
                  • United states
                  #28
                  No video though
                  • ALittlebit
                    • Feb 2015
                    • 51
                    • United states
                    #29
                    Y-main still has lots of low clicks.
                    • ALittlebit
                      • Feb 2015
                      • 51
                      • United states
                      #30
                      So am I looking for burnt spots?
                      • Shinju
                        • Mar 2014
                        • 1239
                        Ok, so the TV is working. The Ydrive upper and lower buffers are attached to the Ysus.
                        Carefully pull the Ribbon plugs off their sticky pads and gently pull up on the white push down pin connectors and then pull the board away from the Ysus after you un screw it.
                        Probably best to take the ymain board out first, seems to be the easiest way to remove the buffers.
                        Snap some photos of the back sides of the upper and lower buffer.
                        Next we will test them to see if they have any shorts.
                        • ALittlebit
                          • Feb 2015
                          • 51
                          • United states
                          #32
                          Buffers
                          • ALittlebit
                            • Feb 2015
                            • 51
                            • United states
                            #33
                            Ready to test for shorts. I have a pretty good multi meter but no skill Or knowledge lol
                            • ALittlebit
                              • Feb 2015
                              • 51
                              • United states
                              #34
                              Could I start the TV up with out the buffers in to see if it drags the ymain down or is that not advised
                              • Shinju
                                • Mar 2014
                                • 1239
                                Remove the Chocolates (the brown deals on the bottoms) See those 4x5 20 hole patterns?
                                After you remove those Chocolates you are going put your DMM into Diode mode, touch your probes together to see if you get a beep. Then you are going to take your GND probe and put it on one of holes on the 4x5 20 hole soldier points and take your positive probe and run it along the pins on the topside were the ribbon plugs into, going on both sides of the connector if you get ANY beeps you have a short.
                                You are going to do this for every 4x5 point and every connector on both upper and lower.
                                Here is a video to help you.
                                https://www.youtube.com/watch?v=51SZsfH60EY
                                • Shinju
                                  • Mar 2014
                                  • 1239
                                  I have ran this TV with only one buffer attached that was not shorted and it worked (only the bottom of the picture was shown.
                                  I am sure you can, I know samsung is pretty forgiving when it comes to running ysus without buffers attached, Do it at your own risk though.
                                  • ALittlebit
                                    • Feb 2015
                                    • 51
                                    • United states
                                    #37
                                    Ok I'll keep you updated shortly
                                    • ALittlebit
                                      • Feb 2015
                                      • 51
                                      • United states
                                      #38
                                      Is this the right mode? If not what one is?
                                      • Shinju
                                        • Mar 2014
                                        • 1239
                                        I am not familar with that DMM but it yes, that is the Diode symbol.
                                        • freakaftr8
                                          • Oct 2012
                                          • 3743
                                          definitely sounds like a short in buffer driving the voltage is down going into reset
                                            09-07-2024, 05:50 AM
                                          • Egidio85
                                            Samsung UE55F8000SZ Turns on and off immediately
                                            by Egidio85
                                            good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                                            This defect happens continuously, hearing the classic click of the relay every time.
                                            Power supply board BN44-00636B
                                            disconnecting the mains and lamps from the power board always causes the same problem.
                                            Is it normal that without anything connected this power supply turns on and off cyclically?
                                            any suggestions on what to check?
                                            thanks in advance
                                            03-11-2025, 12:45 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
