blinking red light panasonic 50" plasma tx-p50c2b
  • sph232
    • Feb 2015
    • 19
    hi i have a panasonic 50" plasma tx-p50c2b im having a problem and could do with some help i'll try to explain the fault as clear as i can.
    when i apply power to the tv i get a very fast flashing green led light followed by red blinking light which is continuous there is also a few clicks as it flashes green light . ive been looking into this for a while now and all leads back to the panasonic blink code chart which goes up to 12 blinking light =sos sound ive tried counting the blinking red led and it has no pause in it it just continuous with about 5 to 7 seconds between each blink is there anyone had this fault or knows what it could be thats causing it im guessing its the a-board (which i get the 3.3v from the power supply but nothing else on the 15v pin and the other i get a reading of 15v when it powers up for a split second then it drops to nothing could anyone help please
  • tw2005
    • Oct 2011
    • 6458
    Re: blinking red light panasonic 50" plasma tx-p50c2b
    A blink and pause of 2-3secs then blink would be 1 blink sos, A board normally.
    Disconnect, Sc2,SS11, P35, 3 white ribbons at the A-board. Turn on Tv and see if you have the same blink code.
    Do not reconnect SC2,SS11 or P35 immediately after turning off, let sit for 5 mins or probe the leads first to make sure no voltage is there or boards & panel can be destroyed.
    there's 200v on the Sc2,Ss11 leads.
    If it's the same , then A board, Ss boards commonly short out so small chance that could cause a wrong blink code,, you can only try it and see.
    • sph232
      • Feb 2015
      • 19
      thanks for reply i will give that ago first think tomorrow
      • tw2005
        • Oct 2011
        • 6458
        no worries, I had the 42" version, doing that the Tv will turn on and stay on if no fault with P or A boards so if it still does the 1 blink it will be A board.
        I discovered later by accident that it had a corrupt eeprom but that's not always the case,
        • sph232
          • Feb 2015
          • 19
          whats a eeprom
          • tw2005
            • Oct 2011
            • 6458
            whats a eeprom
            a chip that can store data eg firmware settings etc. remains after power is removed and can be re written to. I think there's about 4 eeprom and a flash memory IC.
            The A board is like a small computer, it won't run if it's missing parameters, settings, firmware.
            from wiki
            Electrically Erasable Programmable Read-Only Memory and is a type of non-volatile memory used in computers and other electronic devices to store small amounts of data that must be saved when power is removed, e.g., calibration tables or device configuration.
            • sph232
              • Feb 2015
              • 19
              thanks i will give what you mentioned with the Sc2,SS11, P35, in morning if i remember right i done that other day and it showed up different blink code but i'll check it out and i'll look into if there is a way to test the eepromsand flash memory ic thanks very much for your info and i'll report back asap
              • tw2005
                • Oct 2011
                • 6458
                You probably still had the white ribbons connected. It should either turn on or stay 1 blink
                • sph232
                  • Feb 2015
                  • 19
                  i disconnected the sc2 ss11 p35 and the 3 white cables into a board and it resulted in the same 1 blink led
                  • tw2005
                    • Oct 2011
                    • 6458
                    A-board I'm afraid. You could take a gamble and order the panel data eeprom programmed and try replacing it but could be money wasted.
                    i guess you don't repair these as a hobby? Or have any other A-boards laying around from 2010?
                    • sph232
                      • Feb 2015
                      • 19
                      ive just taking it up as a hobby bought a few plasmas and lcd to mess around with ive managed to fix 2 at min ive another 3 waiting on parts and this panasonic plasma ive tried to look about for a A-BOARD for it but theres none available ive not got any a-boards laying around just yet i try and find a place to order one from it'll be worth the gamble as no a-boards available yet
                      • tw2005
                        • Oct 2011
                        • 6458
                        An x20 board would work but there's some notable features different like side Av , on/off switch, USB and additional SCART otherwise would bolt straight in. not sure if the PSU may need a link added or removed. Is the power switch on the front a soft start (momentary push)or is click on, click off
                        • sph232
                          • Feb 2015
                          • 19
                          its a click in one have you got a link or the model number for the x20 one please
                          • tw2005
                            • Oct 2011
                            • 6458
                            on the inside of the rear panel, is there a cutout for the additional SCART but covered by the sticker? If you can get the faceplate for the x20 board(maybe the seller on ebay has it) i reckon it will be fine because all other connectors are there and identical
                            • sph232
                              • Feb 2015
                              • 19
                              Is this what you mean if so whats the chances of it working http://www.ebay.co.uk/itm/PANASONIC-...item3f45d2ba00
                              • tw2005
                                • Oct 2011
                                • 6458
                                other alternative is buy the 42" from SJ and do an EEPROM swap but if it is an eeprom issue the 1 blink can transfer which is good and bad. good because you found the bad part, bad because you would then have to order from a panasonic parts supplier and get new eeprom for 50", good then you could then fix one sell one.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  yep, if that board is good it will work, just an upgraded model, same panel
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Post 14 has the differences
                                    • sph232
                                      • Feb 2015
                                      • 19
                                      yes there is a cut out for rear scart and also there is markings for the extra audio jacks ect on side
                                      • sph232
                                        • Feb 2015
                                        • 19
                                        so just replace with this and all should work i wont have to add any thing extra from power supply or disconnect anything
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • ItepK
                                          Panasonic TX-P42G30E green light blinking, no video, no audio
                                          by ItepK
                                          Hey everyone!
                                          I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                                          This post describes my entire troubleshooting process of this TV.
                                          When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                                          I've taken the unit apart, and I've started to check some voltages:
                                          • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                                          12-22-2023, 05:06 AM
                                        • YasaCh
                                          Sony kdl 40p5500 red light keeps blinking 3 times
                                          by YasaCh
                                          Hello...
                                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                          i opened the back cover no sign of damage on the powery suply or motherboard
                                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                          07-07-2025, 11:53 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
