Another Hitachi P60x901
  • topfli8979
    • Oct 2012
    • 311
    Im working on a Hitachi P60x901, picked tv up with no power. Replaced a couple large caps on power supply. Now tv seems to be powering up, voltages are good at ps. But the screen is not priming? No flashing lights on led, goes from red to blue for about 20 seconds then to orange. From manual I have read that orange indicates no r/c,a/v signal. But shouldnt the screen at least prime first?
  • Jaime Morillo
    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
    by Jaime Morillo
    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
    The TV was stuck on the logo and I couldn't access the update menu.
    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
    The image result was good, but the image is inverted.
    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
    08-18-2025, 11:38 AM
  • serious_electron
    Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
    by serious_electron
    Hello Everyone!
    I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
    06-28-2025, 02:57 PM
  • mosfetratus
    macbook A2918, orange light off when shut off
    by mosfetratus
    When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
    Works with battery and charges, but when i shut off i get this problem.
    It had liquid spill. Board has no corrosion, keyboard is working, power button...
    05-31-2024, 03:34 AM
  • Weelcup
    XPS 9520 not powering up. Solid orange led
    by Weelcup
    Hi friends
    I have a dell XPS 9530 which had some liquid damage to the usb area. I replaced both the usbc iCs and not I can see 20v on the meter. But it does nothing and the 20v is not passing to charge the battery or turning on the board either.
    I suspected the PD controller (usbc controller) but it will need to be flashed if I decide to replace it. I thought that if the usbc controller needs flashing then at least the board should turn on on the battery. I charged the battery externally and attached it to the laptop. Now the 11.8v is actually passed to the board I can...
    10-20-2025, 04:22 PM
  • wolf1976
    hitachi 50hk5600 problem with display
    by wolf1976
    hi
    i have the above tv and the display starts distorts the display at only in applications like you tube
    after and on the didital channels
    now without connect the antenna only the image of itsselfs tv i have the image i have in attach
    i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
    can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
    09-13-2025, 02:26 PM
