Samsung PN60E550 Cannot Confirm Y-Main Failure
    Re: Samsung PN60E550 Cannot Confirm Y-Main Failure
    There shouldn't be any issue using 100V in place of 50V etc.
    • Truncatedhose
      • Oct 2014
      • 343
      That's what I thought, Tom66. Do you have any thoughts on what I should do? At this point, I think I would be okay with making and installing that voltage divider that Drussel conceived and see if that works.
      • Truncatedhose
        • Oct 2014
        • 343
        Well, I constructed a new light saber--err, I mean I constructed the voltage divider and installed it and all works well now. Thanks, Drussell. It's still a mystery, but at least this one is done. Here's hoping it doesn't fail down the road!
        • cliff_hootarski
          • Jul 2006
          • 411
          I have the E530 version of this TV. Mine would fire up and continue to run after I freeze sprayed just the IC. Didn't respond to freezing the cap or opto-isolater.
          I replaced both the IC and cap, but still would not come on with a picture until the IC was freeze sprayed.
          I'm going to try the voltage divider circuit trick and see if that cures it.
          • cliff_hootarski
            • Jul 2006
            • 411
            Thought it was fixed, I put in the voltage divider circuit, turned off and on several times.
            Got a picture every time. Put the back on and crap, back to original problem. Took the back off, tried to turn on, but no picture. Quick shot of freeze spray and bam, powered on and got a picture.
            • Truncatedhose
              • Oct 2014
              • 343
              I have this model again and this one did not work after replacing installing the mod. I've actually fixed about 6 of these before this and they all worked with the mod and just replacing the cap (never had to replace the IC again). This had a history of sometimes working, but when I got to it, there's no panel prime at all.
              Guess I will have to go back to basics on it, but I thought I would see if anyone had any suggestions.
              • Truncatedhose
                • Oct 2014
                • 343
                • npielawski
                  MacBook Pro late 2016 (820-00239) with multiple failure modes.
                  by npielawski
                  I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                  I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                  10-15-2025, 01:53 AM
                • Sus256
                  HISENSE 65E7KQ PRO - no boot
                  by Sus256
                  Hi all!
                  HISENSE 65E7KQ PRO
                  RSAG7.820.13512 - chassis
                  MT9618BAATAB - cpu
                  RSAG7.820.12059 - power
                  HD650Y3U77 - panel
                  KLM8G1GETF - emmc
                  The TV does not turn on, the standby indicator is on. All voltages are present.
                  Emms is dead. Not readable, not detected.
                  Replaced emmc.
                  But with another dump there is no launch
                  Terminal log
                  UART
                  AC_ON
                  RPMB key is not yet programmed
                  HASH1_VERSION=0x00000000 64bit
                  E-B
                  FDE enabled
                  layout pattern onebin by SAR7,0...
                  06-01-2025, 02:11 AM
                • H H
                  3090 FE Part Confirm/Identification
                  by H H
                  I'm hoping someone could help me confirm if I have identified the following parts correctly.
                  Apparently the DP cable became stuck inside the graphics card and was yanked out. This caused some sort of short which burned the DP contacts and blew some resistors and ferrite beads.
                  The parts needing replacement are on the back of the board behind the HDMI input.
                  I have identified the parts as the following:
                  C6037: MLCC 0.1uf/16v(0402)x7R W05
                  R6016: RES 499 OHM 1/16W (0402) 1%
                  LB10911: Ferrite Bead (0402)...
                  02-16-2025, 01:09 PM
                • ctroxtell
                  Carrier HK50AA063 display controller common failure help
                  by ctroxtell
                  I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                  02-05-2025, 05:31 PM
                • howardc64
                  Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                  by howardc64
                  Problem
                  Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                  Model & Board Pics
                  Conflicting Spec
                  Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                  https://www.shopjimmy.com/vizio-gj-2k1...
                  10-10-2024, 01:16 PM
