Magnavox 37md350b/f7 stuck in test mode?
  • zdsh07p9
    • Nov 2013
    • 155
    It goes from red to blue to green to another color and so on, solid colors, cant do anything with the buttons on the bottom of the tv
    How can I get this TV back to regular mode?
    Thanks,
    Zack
  • zdsh07p9
    • Nov 2013
    • 155
    Re: Magnavox 37md350b/f7 stuck in test mode?
    the screen changes solid colors I mean.
    • nuala
      • Aug 2013
      • 37
      Sounds like it is in demo mode. Try this--TO GET OUT OF TEST MODE PRESS CURSOR UP FOLLOWED BY CURSOR DOWN
      • zdsh07p9
        • Nov 2013
        • 155
        I need a remote, haha. I don't think the buttons on the bottom of the screen will work?
        • zdsh07p9
          • Nov 2013
          • 155
          And thanks for the reply
          • zdsh07p9
            • Nov 2013
            • 155
            Will any old Magnavox TV remote work?
            • Dxmen2
              • Oct 2014
              • 13
              • Usa
              hey I have same issue did u fix it
              • Dxmen2
                • Oct 2014
                • 13
                • Usa
                my tv stuck on tv screen test mode different colors pop up can someone help me please its my granpas tv
                • YellowJacket
                  SHARP LC-32CHF5111K - stuck at color test mode
                  by YellowJacket
                  Hi friends,
                  TV has stuck at - as I googled the term - color test mode. Slowly flashing colors white, red, green, blue, black, over and over again. I tried some hints from internet, like pressing some remote buttons, but nothing worked. I also tried factory reset for Sharp TVs => "while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan- " , but TV doesn't even start during buttons pressed.
                  So I decided to flash new firmware to SPI ROM. What do you say, would it help? If so, where can I find some dump? I was unable to find...
                  02-04-2023, 03:11 AM
                • gigigi
                  Panasonic tx-55cx802b stuck on panel test mode
                  by gigigi
                  Panasonic tx-55cx802b stuck on panel test mode.
                  It was working normally but few days ago some of the LED reflectors fall off.
                  I've opened it up carefully, re-glued, while it was open switched it on to test LEDs.
                  Then carefully assembled back.
                  After plugging in to power remote does not work.
                  Using power button on the TV it turns on but gets itself into a panel testing mode: white, gradient, red, gradient, blue, gradient, green and so on switching between colours.
                  Anyone knows how to get out of this panel testing mode?
                  I've tried so...
                  06-20-2021, 07:06 AM
                • The_Memory_Guy
                  Dell T7820 stuck in Bios Recovery Mode
                  by The_Memory_Guy
                  HI,
                  I have a Dell T7820 stuck in Bios recovery mode. I never get Dell Boot screen or anything visible on screen. The system just gives me 3 white lights and 3 orange lights indicating Bios recovery mode.
                  What I have tried to get to recover the Bios, there seems to be some conflicting advice about recovering the system.
                  All of them say to download the latest bios from the dell website which is a .exe file. I have done that
                  https://www.dell.com/support/product...BUT090/drivers
                  Some...
                  07-07-2025, 06:52 AM
                • lab10.haifa
                  Macbook Pro A2338 820-02020 Stuck on RESTORE MODE
                  by lab10.haifa
                  Good day, friends. Got this problem with M1 macbook - it starts, chimes, tries to boot and stuck with a message "support.apple.com/mac/restore"
                  It works with DFU mode, but it's cannot be restored. With "revive" function - same problem. Internal restore mode doesn't work, as well as Internet Recovery.
                  There is no damage on the motherboard. No short circuits.
                  Could it be a NAND problem? (but usually, if NAND is dead - mac simply wouldn't turn on)
                  Thanks....
                  10-08-2025, 02:55 AM
                • ApplePie14
                  iPad Air 4 is stuck in DFU mode
                  by ApplePie14
                  My iPad Air 4 is stuck in DFU mode.
                  I tried restoring it with iTunes but it failed with Error 9. With 3Utools, it gets stuck at “Sending RootTicket” and times out.
                  The PP2V625_NAND line was shorted, so I removed the faulty capacitor and attempted recovery again, but the issue persisted.
                  The short is resolved, but the resistance value is low at 5.5Ω.
                  Measuring the voltage on that line showed 8.3mV.
                  Will installing a normal capacitor resolve this?
                  Translated with DeepL.com (free version)
                  09-04-2025, 03:54 AM
