Panasonic TX-P50VT30E 8 BLİNKİNG HELP ME PLEASE..
  • onurka
    • Feb 2015
    • 17
    • Europa
    Hello..
    I'm new in forum.
    I have a panasonic plasma problem PANASONIC TX-P50VT30E..
    The problem is exactly 8 red blinking..
    The problem is first 7 red led blinking after ı repaired sc borad.. After turn on power..
    After problem now 8 red blinking.. I checked ss board and RCJ330N25 SHORT.. I ordered new ss board and waiting..
    What can ı do?
    help me please....
    By Onur
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: Panasonic TX-P50VT30E 8 BLİNKİNG HELP ME PLEASE..
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • onurka
      • Feb 2015
      • 17
      • Europa
      OK.. but I'm working..May be ı will load to night.
      Is there panasonic tx-p50tv30e service manual?
      By Onur
      • onurka
        • Feb 2015
        • 17
        • Europa
        Panasonİc tx-p50vt30e back picture
        By Onur
        • onurka
          • Feb 2015
          • 17
          • Europa
          Is there any help for me?? please
          By Onur
            Patience!
            The picture is not clear enough. We need a large photo of YOUR TV, not of some image on Google.
            • onurka
              • Feb 2015
              • 17
              • Europa
              Ok.Sorry ı don't understand.. How is photo? Tv energy on/off??
              I will load to night..
              Thanks for helps..
              By Onur
                Something like the one you already posted but it needs to be clearer (more resolution... more megapixels)
                • onurka
                  • Feb 2015
                  • 17
                  • Europa
                  My phone photos
                  By Onur
                  • onurka
                    • Feb 2015
                    • 17
                    • Europa
                    Back
                    By Onur
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      Ok thats not really clear! The picture is upside down.
                      Please post a clear picture from the back of your tv that shows all the prints and how they are connected together.
                      You said you repaired the SC board , did you connect all tabs correctly? Also the white cable that goes to the main board?
                      Did you check Q401, Q402, Q403, Q421 and Q423 for short?
                      • onurka
                        • Feb 2015
                        • 17
                        • Europa
                        I established all components true,I'm sure.. I changed in sc card Q423,Q422,Q421,Q401,Q403 short circuit .. The new ss card came now.. Can ı put new ss card after power on??? Is possible??
                        By Onur
                          SC and SS are not chained together in this model, so I would say it is ok to try it with new SS board. (SC cannot damage it, even if bad)
                          Did you also replace driver IC for one of those Qxxx devices? It is marked ICxxx (xxx = 3 digits.)
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            Turn tv off first!!!
                            • onurka
                              • Feb 2015
                              • 17
                              • Europa
                              I didn't find Buffer ıc (D8693) and Y02 Smd Voltage regulator for Q's.. There aren't !! Is dangerous?
                              By Onur
                              • onurka
                                • Feb 2015
                                • 17
                                • Europa
                                New photo front ... Excus me internet very slowly..
                                By Onur
                                • onurka
                                  • Feb 2015
                                  • 17
                                  • Europa
                                  What can ı do?? I established new ss board... Can ı power to tv??
                                  By Onur
                                  • Neelix
                                    • Oct 2013
                                    • 145
                                    • South Africa
                                    On which board can't you find those parts? On the new SS board?
                                    • onurka
                                      • Feb 2015
                                      • 17
                                      • Europa
                                      No no.. Sc board d8693 ıc Buffer and Y02 voltage regulatör. Ss board is new!!
                                      By Onur
                                      • Neelix
                                        • Oct 2013
                                        • 145
                                        • South Africa
                                        Ok. If you're sure that you fully repaired the SC board and that all the cables are plugged in, then you can power on and see what happens
                                        • riparo
                                          Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
                                          by riparo
                                          Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
                                          I attach a link to download the service manual, thank you for anyone who can help me
                                          https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
                                          01-11-2024, 12:35 PM
                                        • SLB007
                                          Panasonic TX-32C300B stanbye light blinking 13 times
                                          by SLB007
                                          I get no image nor backlight, standby light blinks 13 times then stops. Any clues what it could be no evidence of damaged components
                                          11-02-2025, 04:08 PM
                                        • BigPete
                                          Panasonic Heatpump Dryer Repair
                                          by BigPete
                                          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                          Unfortunately the whole machine has to come apart to fix it.
                                          I have...
                                          11-01-2025, 06:40 PM
                                        • CoinCoin88
                                          Panasonic PF50G20S blinking 13 times
                                          by CoinCoin88
                                          Hello there,
                                          Google led me again to badcaps when trying to troubleshoot a dying Plasma that is sitting at my uncle's roughly 550 km from where I am. It's an old G20 from 2010 or so, that isn't being actively used so you can consider the panel "not too sollicitated".
                                          Symptoms: TV starts, works for 5-10 minutes, then screen turns black and safety kicks in and spits a 13-blink code with the red LED. Once this code kicks in, the TV will not display any image anymore. Unplug it for a few minutes, plug it again, it'll work then fail a few minutes later.
                                          06-30-2023, 05:43 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          11-20-2024, 08:52 PM
