ps50a456 lines just appeared
  • wreksta
    • Aug 2013
    • 508
    • england
    ps50a456 I replaced mainboard on it as ariel broke off
    then there was a big black line either side of the screen
    I left the tv running and loads and loads of lines appeared covering most of the screen
    any ideas will post pics soon
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • cheeky2
    MSI GTX 970 4G V316 1.1 Loads of lines across screen suspect memory??
    by cheeky2
    Recently purchased this MSI GTX 970 Gaming 4G graphics card and card shows plenty of lines when booting up to bios and into Windows.
    What are your thoughts memory issue as I don't have that much experience repairing graphics cards?
    I have checked before plugging in card for shorts on the 12V power rails, PEX etc otherwise I wouldn't have plugged the card into the motherboard.
    The screen shuts down if I load the drivers on the card.
    See attached pictures.
    Any thoughts with what is likely to be the issue? I suspect a faulty Samsung memory chip and if so would...
    05-28-2025, 07:49 AM
  • Stanley1843
    Screen Display Vertical Multicolor Lines
    by Stanley1843
    Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
    06-29-2024, 11:54 AM
  • jeyoung12
    Samsung QN50Q60t lines on screen
    by jeyoung12
    Hi all
    I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
    My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
    This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
    It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
    So....i don't know what end of the C ribbon to work with...
    02-26-2024, 10:38 AM
  • pni
    LG 49uf695v vertical coloured lines
    by pni
    Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
    11-14-2025, 03:15 AM
