Mystery part on Panasonic Plasma P/S TNPA3911
  • saddle_au
    Waste Warrior
    • 121
    I would like a couple of opinions on what part R498 is supposed to be doing.
    I needed to remove capacitor C447. But to get it out, I had to remove some other parts that were in the way (there's an overhead heatsink limiting vertical extraction). On locating the pins for R498, I find they are (very obviously) wired together on the PCB. I think the part serves no purpose other than ballast, artificial cost increase or some engineer justifying the time taken on a board. "It took a while because look how complex this is!".
    Has anyone seen this before?
  • CapLeaker
    Leaking Member
    • 8177
    Re: Mystery part on Panasonic Plasma P/S TNPA3911
    [QUOTE=saddle_au;522218]I think the part serves no purpose other than ballast, artificial cost increase or some engineer justifying the time taken on a board.QUOTE]
    you forgot one: Free parts to give away!
    • dkneyle
      • Dec 2013
      • 441
      I saw just the same situation on a board the other day in the power supply section. I think often the original circuit called for a very low resistor, sometimes used for current monitoring. Then revision changes result in it being changed to a short circuit link. It's the best explanation I've been able to come up with.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4958
        • New Zealand
        Design error or maybe it's a spare?
        -David VanHorn
        • tw2005
          • Oct 2011
          • 6458
          I don't know if it was the same board but someone else has reported something similar on a panasonic plasma PSU before. exact same scenario, soldered to the same land
          • saddle_au
            Waste Warrior
            • 121
            How about:
            1) engineering challenge, keep stuffing parts on there until someone else notices.
            2) An engineering where's Where's Wally (UK, AUS) game (Where's Waldo US).
            3) The power supply was quoted at $X and that's what it will come in at no-matter what.
            4) earthing posts for testing (more expensive than a wire link, but hey why not)
            5) new storage option for spare parts, get the owner to hold them for you on parts you know will fail
            5) Put the part in there to purposely get in the way of a repair
            6) 1st April: Put out a service bulletin describing a failure of voltage across it causing massive problems
            • Agent24
              I see dead caps
              • Oct 2007
              • 4958
              • New Zealand
              I thought spare initially but a 100 Ohm 5% resistor is not exactly hard to find...
              The idea of a ground post is a good one - if they already had heaps of these resistors, it would be easier and maybe even cheaper actually.
              -David VanHorn
              • Yanleb
                Panasonic part number in service manuals
                by Yanleb
                In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                For an example, look at the attached PDF.
                Do you have a way to cross reference the Panasonic part number with the actual part number?
                Thanks....
                07-03-2023, 08:16 PM
              • jm1234
                Panasonic plasma TX-P42ST50 - 6 blinks
                by jm1234
                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                I checked that board for any obvious faults...
                05-22-2024, 06:59 AM
              • stecos
                Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                by stecos
                Hi everyone!
                For my passion for technology I'm now collecting several...
                11-28-2022, 11:39 AM
              • cloo
                Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                by cloo
                I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                After doing a factory reset this problem was gone and the picture was back to...
                01-06-2025, 06:02 AM
              • Alicat
                Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                by Alicat
                Stopped by this site trying to fix my parents Panasonic Plasma TV.
                Model number is TH-50PZ85U
                Power comes on and the red power light stays on solid.
                Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                I also hear a few clicks.
                I also think my parents said there was a thunderstorm and the TV failed after that.
                Section 6 in the service manual talks about power and no screen,...
                10-30-2024, 10:09 AM
