lg42pj350 clicking cycle on start up
  • daphney
    • Feb 2014
    • 93
    • uk
    i have read posts on this tv & made some progress i think maybe...
    when i got didnt show any pic & just clicked cycle i replaced 2 30j124 & 2 30f124 on ysus then turned on worked for a few mins with white strip at bottom like in other posts then stoped & back to clicking. found the 2 f124 &2 j124 s i had replaced had short again & the 3 2.2ohm resistors gone . so replaced that & now the clickin is back but is only the j124s that shorted but i got no pic at all this time have checked the green resistors out of circuit & check ok any ideas please
    thnx as always
  • TinkerTron
    Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
    by TinkerTron
    Hey everyone,
    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
    Instead, here's what's been bugging me so far:
    The schematic...
    03-06-2025, 02:03 PM
  • Eniaro
    MacBook Pro 2019 A2159 (2-port) wont boot
    by Eniaro
    Trackpad clicks.
    Plugging in a genuine USB-C charger and any other charger = 20V and charges all the way.
    Plugging in a Dell USB-C dock or monitor causes the voltage to cycle endlessly between 5V and 19V
    The Caps Lock button doesn't illuminate.
    Holding the power button (fingerprint scanner) for 10 seconds stops the trackpad clicking temporarily, but it starts clicking again after 3 seconds.
    If I open the lid slightly, the trackpad stops clicking (it seems to be detecting the lid opening/closing).
    The keyboard backlight...
    11-27-2024, 04:25 PM
  • meraklinetx
    Asus Z97-a power cycle, no boot no cpu voltage
    by meraklinetx
    Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
    05-10-2023, 06:08 AM
  • karatzdi
    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
    by karatzdi
    I know some might say... just buy another one. Sell it as parts..!
    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
    Spent some time downloading the Service...
    06-11-2024, 08:38 AM
  • spice_disc
    Vizio TV M50-C1 reboot cycle and static on screen
    by spice_disc
    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
    09-08-2024, 02:37 PM
