Looking at fixing my T.V. - Panasonic TX-P42G30B
  • tombry
    • Jan 2015
    • 6
    • England
    I'm looking at trying to fix this, as opposed to going out and buying a new one, as I'd really rather not buy a new TV right now - if I can't fix it, I'll just have to put up with it until I can buy one, so I'm hoping you all can give me a quick idea of whether I should spend my time tearing it apart and such.
    So the tv has recently started having issues when starting up, it's most noticeable when my PS3 is first turned on, as the XMB ribbon gives it fits - all the white parts look almost like static made up of all the colors - red, green, blue, and white, this will go for a while (but only seems to effect moving white - if it's a solid white like EAs logo, no flickering).
    I've also noticed that the top third/half of the screen looks faded, and is effected more than the bottom half/two thirds.
    I'm kind of hoping it is going to turn out to be one of the cheaper boards that is the issue.
    I'll be buying a digital multimeter tomorrow, as I don't currently have one, but it would be good to know where I'm starting, as I've read the tom66 guide on plasmas, and I'm not sure that any of the things he mentions there is my issue...maybe the sparkles one.
    So does anyone have an idea of what it might be?
  • sordids999
    • May 2013
    • 2155
    Re: Looking at fixing my T.V. - Panasonic TX-P42G30B
    posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • tombry
      • Jan 2015
      • 6
      • England
      will do - I'll take it apart tonight then, and try to get good pictures.
        A video of the fault would help too. The sparklies section won't apply to your set as there is no way to adjust these Panasonic sets.
        • tombry
          • Jan 2015
          • 6
          • England
          TV issue: http://youtu.be/do9FUACJQ8M
          From the preview on my phone its most noticeable during the dairy queen commercials fan food image that is loaded with white.
          Going to tear it apart tomorrow after I buy my multimeter, don't need the TV on the floor overnight
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Video is so low res and so poor cant see anything much!
            How about some nice high-res. still images showing the problem?
            TELEFIX
            • CapLeaker
              Leaking Member
              • 8214
              I think I see it. right on top left and right of the cloud on the DQ commercial. First when I ran the video for a second, right at the beginning, it looked like a gamma chip problem? I had a TV last week that had a picture similar to that. Came to find out that there was some corrosion on the tab between the LCD and T-Con. I cleaned the tab and connector with alcohol, then put some deoxit on there, plugged it back in and all was well, gamma corrected.
                Well, this is a plasma, so a gamma IC fault wouldn't apply.
                I think it would be a good idea ot enter the service menu and check the patterns there: I'll have a look at how to do that on this US model
                • CapLeaker
                  Leaking Member
                  • 8214
                  didn't realize that it was a plasma.... ignore my other post. However I see what he is talking though on the DQ commercial.
                  • tombry
                    • Jan 2015
                    • 6
                    • England
                    4K TVIssue: http://youtu.be/m5AlEsGhqZM
                    There it is in 4k, that purple flickering in the white parts, forgot my phone has a HD option
                    • tw2005
                      • Oct 2011
                      • 6458
                      I'd shut it down and check the SN board mounting screws. they could be loose and poor earthing. If loose, may be a good idea to look on the back of the board and chassis for arcing / burn marks.
                      • tw2005
                        • Oct 2011
                        • 6458
                        The screws
                        • tw2005
                          • Oct 2011
                          • 6458
                          also, If you have a meter that can measure over 200vdc, check what Vsus is set to.
                          • tombry
                            • Jan 2015
                            • 6
                            • England
                            Well I finally got time to take the T.V. apart - didn't feel any loose screws on the boards, and didn't notice any scorch marks anywhere.
                            I took pictures of the boards in the back - doubt anyone will be able to see anything from them, but if you do that'd be awesome.
                            I'd really like to keep this damn T.V., and am not looking forward to having to buy a new one.
                            • Chrissygizmo
                              Panasonic TX-48CX350B backlights but white screen , blank screen
                              by Chrissygizmo
                              Hi all, I’ve got a problem I hope someone can help me fixi.
                              I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                              01-11-2025, 03:18 PM
                              MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                              This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                              09-06-2024, 07:46 AM
                              MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                              This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                              09-06-2024, 07:29 AM
                              MSI Prestige P65 8RF-445ES Creator White Notebook P Specification for Upgrade or Repair
                              This specification for the MSI Prestige P65 8RF-445ES Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-445ES Creator White boardview and P65 8RF-445ES Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                              09-06-2024, 07:25 AM
                              MSI Prestige P65 8RF Creator White Notebook P Specification for Upgrade or Repair
                              This specification for the MSI Prestige P65 8RF Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF Creator White boardview and P65 8RF Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
