RCA LED TV model # rled3258a-c
  • christo
    • Jan 2015
    • 25
    • canada
    Doesn't turn on all the time, gotta unplug it multiple times for it to finally turn on.
    I've replaced all capacitors circled in red, the ones I haven't are circled in blue.
    Any idea what could be causing this?
    The ones in blue haven't been replaced because I've run out of caps.
    I only have a analog multimeter atm.
  • paulstef
    • Dec 2013
    • 724
    Re: RCA LED TV model # rled3258a-c
    It's a crap TV. probably the mainboard. Look at this thread it uses the same mainboard.
    https://www.badcaps.net/forum/showthread.php?t=32351
    I have two of them with exactly the same issue. There is no signal from the mainboard to the LED driver board.
    Don't know what is causing this on the mainboard. Baking doesn't help. In both cases it got progressively worse. Maybe bad solder joints on the BGA chips?
    • christo
      • Jan 2015
      • 25
      • canada
      I'll check the main board out, but i was almost certain that it was a power supply issue, thanks for the tip.
      • paulstef
        • Dec 2013
        • 724
        In both my cases all voltages from the PS are present. Once I turn on the TV it freezes and no signal to backlight circuit.
        There is a small crystal 25MHz on it. Removed it to see if I could still turn on the TV. I couldn't. This means the uC is needed for power on but then it freezes for unknown reason. A similar failure is where it turns on the backlight and THEN freezes. Maybe it tries to communicate with eeprom or memory and it's there where it stops. Who knows. The set is so cheap, if we would want to troubleshoot the board itself it would be only for personal pleasure. :-)
        • christo
          • Jan 2015
          • 25
          • canada
          I'm gonna bake the main board for shits and giggles. I'm done trouble shooting the motherboard it must be something else
          • nicholas1110
            • Aug 2012
            • 127
            • usa
            Hello, your symptoms sound like a bad eeprom on the main board. I have replaced many on these newer rca TVs.
            • christo
              • Jan 2015
              • 25
              • canada
              I baked it in the oven 375 F for 10 mins, tv actually works better now but still not turning on every time, I had it turn on and off 3 times without unplugging it.
              I might bake again see what the results are. If it doesn't take this time I'll look into getting a new board or a eeprom chip
              • christo
                • Jan 2015
                • 25
                • canada
                Update, I baked it again, thing powered up and worked mint... Until i plugged my laptop and wii in to find out there's no sound xD.
                I'm now going to take the main board off, look at the soldering joints for the the other board that clips into the main board. I hope it's a cold soldering joint or i'll be tossing it in the oven for a third time, I am making pretty good progress though just by baking it lol!
                • CapLeaker
                  Leaking Member
                  • 8221
                  The caps don't like to be baked. There is a temperature rating on them. As hotter they get, less life they will going to have. Did you install the board, when it was still warm?
                  • christo
                    • Jan 2015
                    • 25
                    • canada
                    No I didn't install when still warm I let it cool for 20 minutes and popped it in. I know the caps don't like to be baked because I had to replace 3 xD
                    I'm gonna pull all of them this time around.
                    • christo
                      • Jan 2015
                      • 25
                      • canada
                      Could the caps that I left on the board cause the no sound? I'm gonna replace those first before I. Bake it again
                      • christo
                        • Jan 2015
                        • 25
                        • canada
                        Just like to do my last update, I switched all the caps once over, still no sound.
                        After fiddling I realized I had two cords mixed up and put them in their correct location. Tv is up and running fine will report back if it messes up again.
                          HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                          This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                          09-06-2024, 05:27 AM
                          HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                          This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                          This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                          This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        • amigo744
                          LG OLED 55CX9LA SWAP MAINBOARD FROM NEWER MODEL 55CS9LA POSSIBLE???
                          by amigo744
                          i have an 55cx9la tv fully functional.
                          furthermore i have a new mainboard from newer model oled 55cs9la / cs series.
                          Both Mainboards look the same and the connectors to the t-con board and psu are also the same.
                          Only one connector which leads to the wlan/bluetooth and power led is different.
                          Anyone here, who tried to upgrade lg cx series to newer cs series ????
                          Is that possible ?
                          How to power on the tv for test purposes without plugging in the power on/bluetooth/wlan connector, because it is different and does not fit...
                          02-10-2024, 03:05 AM
