Toshiba 40LV655P
  • abdekader
    • Jul 2014
    • 73
    • Turkey
    Toshiba 40LV655P
    I have Toshiba 40LV655P negative image
    how i can fix this problem , i changed the T-con but the same problem
    Electronic Engineer from Syria,Aleppo
  • abdekader
    • Jul 2014
    • 73
    • Turkey
    Re: Toshiba 40LV655P
    nobody know how to fix this problem
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Check the T-CON board and see if it is getting power. If not it could be the MOSFET on the Main Board that switches power to the T-CON.
      This negative pic is most times caused by a T-CON failure.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Can you post a picture of something simpler on the screen without the OSD even if the colours were reversed I couldnt tell what it is. Post using manage attachments not off site
        Can you find a factory reset in the menu.
        Check the lvds cable.
        If it has video out how does it show on a monitor.
        • AFajitas
          • Dec 2014
          • 183
          I had a LG with the same exact negative picture issue. it ended up being a firmware setting in the service menu, it was doing this because the panel type was set to JEIDA instead of VESA.
          • abdekader
            • Jul 2014
            • 73
            • Turkey
            i want fix this problem from service menu (menu from tv and mute from remote control )
            but i don't know (HEX code) to my TV 40LV655P
            • AFajitas
              • Dec 2014
              • 183
              Looks like a german dude fixed it here.
              he never gave up the hex code and the thread declined into mistaken racism over the OP's nickname. I sent him an email translated into German maybe he'll reply back.
              Another way you could fix it is to find someone with the same model TV and have them relay their hex codes to you.
              • abdekader
                • Jul 2014
                • 73
                • Turkey
                i have the same problem to this person but i don't understand anything because in german
                if he send to you the solution send it to me please thank you
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  Why did you not tell us the pictures are NOT off YOUR set?
                  • AFajitas
                    • Dec 2014
                    • 183
                    Success! I heard back from him.
                    Hello Justin,
                    i dont know, waths exactly is your problem.
                    If your problem not correct colors, then can you fix this with folloeing steps:
                    1. TV switch on.
                    2. press Mute-key on telepilot (Symbol speker will on the screen)
                    3. press now on tv-panel the menue-key + the mute-key for 6 to 10 secunds together.
                    On screen will be now the Info "S" vor service-mode.
                    4. Use now up/down on your telepilot, as on screen will be "Modell"
                    5. if on screen "Modell" present, press on telepilot the +key for audio up, as on the screen is the HEX-Code (02H for 40LV 655P),[ 01H for 32LV655P.
                    6. press together on telepilot the "Info-Taste + on the TV-Panel the key "Audio +".
                    7. Then switch off the TV and start new.
                    The Problem with the missing colors will be clean.
                    If you have a other problem, for example switch of/on, may be help to change the capazität "C 1124" from 8pF to 5,6 pF. I'am not sure, to clean the releis-klicking with this, but i think, this modell has a problem with timing to read the eeprom "IC 101". In most times you can with hot aer on this areal reproduce the switch on/off effects.
                    sorry for my translation in a not correctly english, but i hope you can understand und i can help you
                    Werner Reisinger
                    • nomoresonys
                      • 12206
                      • U.S.
                      Nice work AFajitas, would be nice if EVERYONE here were as helpful as you are, instead of just posting critical non-helpful snide little remarks, good work.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8179
                        To translate a few more words:
                        telepilot = remote control
                        capazität = capacitor (he meant to say)
                        This kind of "fix" may work on other TV's too where the same mainboard is used on same brand, but different size panels.
                        • AFajitas
                          • Dec 2014
                          • 183
                          Thanks. I'm still really inexperienced at electrical repair work but I'm good at solving problems in general. I'm going to need a lot of help and hand holding, so trying to give as much back as I can.
                          • abdekader
                            • Jul 2014
                            • 73
                            • Turkey
                            thank you veru much AFajitas and for all , REAL FRIENDS
                              09-06-2024, 05:27 AM
                            • delphi_firebird
                              Toshiba Qosmio X755 Charging problem
                              by delphi_firebird
                              Hello Guys,
                              I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
                              - When battery is unplugged i works without any problem.
                              - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
                              - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
                              Can you help me diagnose the problem? I have attached...
                              10-16-2023, 03:04 AM
                              09-06-2024, 05:59 AM
