Remote controls for "off-brand" TV's
  • Jooo
    • Oct 2011
    • 222
    • Finland
    Where do you get them? I have couple of TV's fixed and ready to go, but haven't been able to find remote controls for them. Two of them are "Art Mito" and one "Audix"
    Ebay, amazon have been no help. I don't care if it's new or used. Haven't found even a 1:1 compatible remote.
    I have been lucky a few times and found some cheap used remotes for obscure brands at flea markets, but that's like looking for a needle in a haystack.
    Re: Remote controls for "off-brand" TV's
    I usually buy them by the OEM. So if the set was built by vestel, most vestel remotes will work. Or, you can see what other sets use the same boards, maybe those have easy to get remotes.
    • cstout
      DeLonghi AC Remote only accepts 3V
      by cstout
      Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
      The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
      I can't find any schematics...
      06-03-2024, 03:53 PM
    • Dannyx
      "Kinetic" 433Mhz transmitter/receiver discussion
      by Dannyx
      Good day folks.
      TL;DR: has anyone tried pairing one of THESE "kinetic" battery-less switches with THESE generic remote modules ?
      Details: I recently got hit by this craze of wanting to add remote controls to the lights around my house, so I went with those generic 433Mhz remote relay modules found everywhere, which are really basic, easy to use and work well, since I used them before in other projects. What I like most about them is they accept all kinds of 433Mhz remotes that float around Aliexpress, since they're all the same under the hood, save for the...
      03-08-2022, 11:01 AM
    • tmhobadcap
      Pioneer VSX-522-K remote control not working???
      by tmhobadcap
      I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
      At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
      12-24-2020, 01:44 AM
    • rustinjust
      Please help, where can I get a remote for my subwoofer?
      by rustinjust
      I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
      Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
      Is there...
      10-28-2023, 03:43 AM
    • jesterace
      Samsung B2030HD IR Remote Receiver Dead, shorted micom?
      by jesterace
      I have this TV a small 20 inch that works perfectly except for the IR has stopped. I have confirmed that the remote control is fine and tried an alternative and even tried with IR blaster from phone. Remote 100% ok.
      Tried installing latest firmware but no change.
      TV won't respond to remote at all, not even to bring it out of standby. I have to use the touch sensitive front panel to operate, at which point TV is usable albeit with no remote.
      Tried replacing the IR receiver diode/bulb on front panel and no change so put the old one back. After tracing...
      10-26-2022, 02:20 AM
