LG 50PC1D Picture Problem...
  • StephenU
    • Dec 2013
    • 230
    Afternoon and Happy new Year to one and All.
    Looking for some help troubleshooting a LG50PC1D Plasma (DOM 2007)
    Collected TV, usual power board failure, replaced 13, yes 13 duff caps on the power board alone, I have one more to replace but waiting on it arriving as thought i had ordered, anyway...
    TV now powers up with sound, picture is very 'Speckled' like static but coloured speckles, using a DVD as a source, can see a picture but really dull and speckled. (Could this be the CAP on PSU that i still have to change causeing this? 680uF 50V)
    In the past dealing with Samsung plasmas I would do some adjusting on the Y-Main to rectify this as much as possible, tried it with this set and nothing to any great effect happened.
    Anyone any ideas where next to start. TIA
    (Va checks out correct and so does Vs - From PSU side of things.)
    (( Will upload pics soon as possible - unless i'm told to Junk the thing!! ))
    Stephen
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: LG 50PC1D Picture Problem...
    Pictures of the fault would be helpful. However, this sounds like a bad Z-SUS board to me.
    • doorzon
      AOC AGON AG273QCG refresh problem picture shifts
      by doorzon
      hopefully someone on this board has an idea on how to begin with troubleshooting this problem.
      The monitor AOC AGON AG273QCG (curved 27" QHD monitor) has problems refreshing every 1 to 2 seconds or so. A line appears in the middle of the screen and the lower half of the screen is shifted to the right.
      See attached picture.
      I am leaning towards an issue with bad soldering of the graphics chip, because the problem used to go away after some time (minutes) but now it is here to stay.
      However, this could also be related...
      08-12-2023, 02:36 AM
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • retrorepair
      SONY KDL-40P3600 Picture Problem
      by retrorepair
      Hello gurus, hope you can assist me...
      I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
      I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
      Thanks in advance.
      10-11-2024, 05:12 PM
    • KYBOSH
      Samsung UN55MU8000 - Backlight But No Picture Problem
      by KYBOSH
      Hello all
      I pick this up free as a repair project for the holidays.
      The original symptom was power cycling after 3-4 seconds with a single red light flash.
      To remedy this I went through and unplugged each component 1x1 and discovered that when the FFC cables were disconnected the backlights stayed on and the TV did not reboot.
      I tried remove one or the other to see which side of the display was causing the issue (expecting to see half a picture to show) but didn't see anything. But the boot loop only appears when the top FFC cable (right side...
      12-21-2022, 12:42 AM
    • Rusenga
      Samsung PS43E450A1R Picture Problem
      by Rusenga
      Hie techs, I have a samsung plasma TV which when plugged in shows a very dull reddish image. Tested some voltages and below is what I get:
      Note the green light on the tcon flashes every second.
      Power supply board:
      PS on 0v
      Stby 5v
      VS CON 1.72v
      VS ON 3.2v
      VS 208v
      VA. 57v
      X buffer :
      Svt vs 209v
      Svt xout>flactuating between 280 to 900v
      Y main board:
      Svt vs. 208v
      Svt ve. more than 1000v
      Svt yg c More than 1000v
      Svt yout flactuating between 400v and 1900v
      Svt...
      11-24-2023, 09:26 AM
