Samsung LCD LE37A656A1FXXC , trouble starting up!
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Samsung LCD LE37A656A1FXXC , trouble starting up!
    Or is it a panel faillure?
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Here are some pictures! The last pictures is the back of the FRC board.
      This board gets really warm when i turn on the tv , if you look closely you see some burn marks , im not sure if thats from the factory or that it just blew....i guess it just blew?
      Backlight is working perfectly.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        This is the board that gets really hot! More warm then the PS....
        Its connected between the mainboard and the T-Con.
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • FreakyMex
          Trouble to identify part (Lunii screen) for replacement
          by FreakyMex
          Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
          I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
          02-17-2025, 01:16 AM
        • Chrissygizmo
          samsung galaxy ao2s very temperamental after screen replaced
          by Chrissygizmo
          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
          Ive eventually managed to get it on and working but it's very temperamental...
          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
          05-26-2024, 12:05 AM
        • JunkmanJimbo
          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
          by JunkmanJimbo
          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
          Please help. Thanks in advance!
          08-12-2025, 11:45 AM
        • Kiberge
          Samsung LH82QENELGC/EN Help needed - Static line on screen
          by Kiberge
          HI guys!
          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
          04-22-2024, 11:28 AM
