Sharp lc-60le745u, blinking light
  • Falcons2677
    • 19
    Hello all,
    I have a sharp lc-60le745u with blinking light syndrome. 1 slow 1 fast will not turn on. I tried volume - channel - and plugged in with no change. I then tried channel - and input plugged in tv came and has been on since roughly 6hrs now. Should I not worry about it as long as its working? Is something going bad? Any thoughts or suggestions?
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Sharp lc-60le745u, blinking light
    Is this the same TV you started this thread about? If so, you can start by not double posting.
    https://www.badcaps.net/forum/showth...995#post514995
    • Falcons2677
      • 19
      Yes not sure how but it got double posted. A mod can delete one of them. I am still uncertain of what caused the problem and what to do if it returns. any and all help would be appreciated.
      • johnboy1313
        • Nov 2012
        • 1959
        Did you bother looking at the other thread?
        • Falcons2677
          • 19
          Yes, I did check other post. I will order a spare led to change the bad one. Thanks for your help.
          • Fergal22
            Samsung UE40F5300AK blinking red light
            by Fergal22
            I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
            When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
            I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
            Any help would be appreciated...
            02-02-2023, 09:19 AM
          • norbiszoke
            Samsung 50AU7172, only blinking red light
            by norbiszoke
            We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
            Regards, Norbert!...
            04-17-2024, 06:54 AM
          • matty24
            Samsung UE50MU6172 - red light blinking
            by matty24
            Hello. I have problem with Samsung UE50MU6172.
            TV won't turn on, red standby light is blinking.
            Power supply BN44-00807A is fine. I replaced it with the new one.​
            Main board BN41-02568B (BN94-12530E)
            I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
            03-02-2025, 08:57 AM
          • huzo
            HP 470 G5 blinking amber light no power
            by huzo
            The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
            So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
            I've tried flashing the bios...
            interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
            06-08-2023, 04:08 PM
          • 1centchips
            Asus rog strix g1614jv-Is96 freezes at random times and blinking charging light
            by 1centchips
            I have the i9 version. I have tried disabling intel and Nvidia graphics in the device manager.
            The laptop is just out of warranty.
            The laptop continues to freeze randomly with the blinking amber charging light.
            What could be possibly wrong with it?
            I have also disable armoury crate in bios.
            12-17-2024, 05:18 PM
