Sharp LC-70LE55OU No video
  • bradam
    • Dec 2014
    • 7
    • usa
    So my 70 inch sharp TV decided it doesn't feel like displaying any picture anymore
    If left off for a while, when you very first turn it on, you get picture for a few seconds then it freezes and kind of fades away, but the backlight stays on. You can turn the tv on and off again but you just get a backlit screen. The white led in the bottom front stays lit up white and doesn't flash at all that I can notice for codes.
    Tried factory reset, leaving it sit unplugged a few days, same issue.
    Bought a new power supply hoping that was the culprit but same issue. So I tried replacing the Tconn board but still no picture.
    Oddly enough if you disconnect one of the 2 ribbon cables connected to the Tconn board you can get picture on one side of the tv screen or the other. However one of the sides will stay on but with the other ribbon disconnected that sides picture fades out after a few seconds.
    So I'm guessing its not the main board but a problem with the panel itself possibly?
    Any help/suggestions is much appreciated!
  • leggot
    • Oct 2014
    • 50
    Re: Sharp LC-70LE55OU No video
    I would guess that you have a loose connection with one or more of the ribbon cables, try wiggling them around/reseating them. I have had situations where you can shim ribbon cables at their point of connection to get a good signal.
    Another good test is tapping the connections to see if that fixes the issue, that would be a good indicator of a loose connection.
    • bradam
      • Dec 2014
      • 7
      • usa
      With them both plugged in you initially get picture but it quickly fades away, its only with one of them removed there is a difference.
      If your facing the back of the TV and disconnect the right ribbon cable then walk around to the front of the TV the left side of the screen is white, but the right side has picture and it stays on.
      If your facing the back of the TV and disconnect the left ribbon cable then walk around to the front of the TV the right side of the screen is white, but the left side has picture for a few seconds then it fades out and goes black.
      So that made me wonder if there's something possibly wrong with left side of the panel?
      Also found it odd that with one of the ribbons disconnected the tv powers on and doesn't flash any error codes.
      • leggot
        • Oct 2014
        • 50
        Have you tried any of the tests I mentioned in my last post? Hopefully they will help determine if this is infact a connection issue with the ribbon cable. It is relatively safe to touch the ribbon cables when the tv is in operation as long as you stay away from the power and inverter boards where the high voltages are.
        If this doesn't work it may be a heat sensitive issue or a tap bonding issue; however its best to eliminate one issue at a time.
        • mmartell
          • Oct 2013
          • 3189
          Sounds like a panel issue.
          • bradam
            • Dec 2014
            • 7
            • usa
            Ended up setting up a mirror on the other side of the tv so I could see heh
            Short of straight disconnecting the ribbons I saw no difference tapping or wiggling them
            • bradam
              • Dec 2014
              • 7
              • usa
              Is there any repairs that can be done on the panel? Ole google is failing me on that one.
              • leggot
                • Oct 2014
                • 50
                Try using a hairdrier to heat up the connections or compressed air can upsidedown to cool down the connections to see if that makes a difference.
                Otherwise, if you eliminated the tcon board, then it could be a bad ribbon cable or panel, I doubt that its bad bonding.
                • bradam
                  • Dec 2014
                  • 7
                  • usa
                  The replacement ebay tcon board came with 2 ribbons attached, tried both boards with both sets of ribbons, same problem either setup.
                  • nomoresonys
                    • 12202
                    • U.S.
                    see if you can find a firmware update, couldnt hurt.
                    • leggot
                      • Oct 2014
                      • 50
                      Have you tried messing with the other end of the ribbon cables attached to the main board?
                      • nomoresonys
                        • 12202
                        • U.S.
                        could try cleaning your tcon cable aka lvds cable contacts with an eraser, I think you can clean the tabs to the tcon too.
                        • bradam
                          • Dec 2014
                          • 7
                          • usa
                          Have swapped out the ribbon cables, they appear fine though. No signs of corrosion or anything. It takes a bit of finesse to get them on and off the bottom of the tv.
                          Was fiddling around trying to update the firmware but I can only see half the tv screen and can't read the steps.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            It does sound like a panel issue to me too sadly. shorted voltage on one side of the panel. with both plugged in in the initially get a picture and it fades away and if you unplug one side and it stays on that definitely sounds like a panel problem. you could always go for the t-con board but I really don't think it's going to fix matters unfortunately
                            • Tr0ll
                              by Tr0ll
                              Original T-con:
                              First replacement T-con:
                              10-07-2023, 07:48 PM
                            • scubacamper
                              Sharp Aquos LC-70C6400U Half Screen Dark
                              by scubacamper
                              I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                              Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                              when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                              05-03-2025, 12:19 PM
                              HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                              This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                              09-12-2024, 02:00 PM
                            • Ierwin
                              Philips 58PUS7805 Menu working but no/weird picture from video sources
                              by Ierwin
                              I got a 58pus7805 that shows some weird behavior.
                              The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                              However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                              I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                              I managed to install the latest official firmware by holding the control button while plugging...
                              03-10-2024, 12:50 PM
                              GeForce RTX2080 Super Aero video gaming card issues help need
                              This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                              Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                              05-07-2023, 08:12 AM
