jvc LT-37X688 HDMI not working
+ More Options
Posts
  • nomoresonys
    • 12266
    • U.S.
    hdmi not working, did a diy tab bond fix, wondering if a firmware update or replace will fix, naturally jvc has no firmware for it, hesitate to take back off, was tough getting the tab just right, Thanks.
  • nomoresonys
    • 12266
    • U.S.
    Re: jvc LT-37X688 HDMI not working
    anyone know where I can find firmware for it, thanks.
    • freakaftr8
      • Oct 2012
      • 3743
      I'm not sure about the firmware but there always could be a problem with the mainboard I have seen in the past HDMI controllers being taken out by voltage spikes static electricity or lightning strikes going through the HDMI port from the source of whatever it was connected to. Do you know the history on the TV?
      • nomoresonys
        • 12266
        • U.S.
        dont know history, was a throw away cuz of bad panel bond, thought maybe firmware would revive the hdmi, not sure tho.
        • jayakumar
          dell 5490 la-f401p no display ( in HDMI out working )
          by jayakumar
          I have dell 5490 la-f401p problem: no display ( in HDMI out working )
          changed working bios ,working screen ,cable
          Please help me to resolve the issue
          i have more then 7 laptop's having the issue
          08-06-2024, 10:03 PM
        • macabook
          πŸ› οΈ MSI GP75 Leopard MS-17E71 – No Display, Deep BIOS/EC Troubleshooting
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • BadTelly
          HDMI ports not working - Panasonic model number TX-P50XT50B 50"
          by BadTelly
          Suddenly all HDMI ports stopped working on a Panasonic 50" TV. This is model number TX-P50XT50B and has worked fine for years.
          The TV turns on but no joy on either HDMI-1 or HDMI-2 and I've tested it using an input device and cable that works fine on another TV via HDMI.
          Thank you in advance for any help/ advice.
          Kind regards,
          Bad Telly
          11-26-2022, 11:26 AM
        • grimacelord
          Samsung UN50MU6070FXZA - HDMI Ports Not Working
          by grimacelord
          Hello. Samsung UN50MU6070FXZA here with both HDMI ports non-working. I have already verified multiple sources and multiple cables to ensure it isn't something simple like that as well as resets and software updates.
          I took the mainboard out and gave it a look. Nothing looks bad or burned. All of the HDMI pins are nice, none are broken at their pads either.
          Following the traces, it looks like both HDMI ports trace back to the main CPU which does seem to get hotter than I think it should despite it's (rather poor) heatsink.
          Since the HDMI controller appears...
          11-03-2021, 03:10 PM
        • mavaro
          MSI GF63 MS-16W21 - Black Screen LCD - Working HDMI
          by mavaro
          I have an MSI GF63 laptop with a MS-16W21 motherboard on my table, and there is no image on the LCD screen. However, when connected via HDMI, the image displays correctly.
          Voltages on the EDP 40-pin connector pins:
          3pin = 012V,
          5pin = 1.75V,
          6 pin = 5V,
          7 PIN = 3.3V
          32 PIN = 2.2V
          33 - 36 PIN = 3.3V
          38-40PIN - 19V
          PU21 - MP2143
          1 - 5V
          2 - 5V
          3 - 3.3V
          4 - 0V
          5 - 3.3V
          6 - 0V
          7 - 0.6V
          8 - 3.3
          Help me please ...
          03-12-2025, 04:39 AM
