toshiba 40ft2u1 works cold
  • freakaftr8
    • Oct 2012
    • 3743
    so this TV I picked up I was told by the original owner that it quit working. It was left unplugged for 6 months. When I plug it in it works flawless. And it'll work all day but if you turn it off and you try to turn it back on the back light comes on and then shuts off but the green light stays on no 12 volts no picture no action on the screen without backlight either. It was basically dead. sometimes if you unplug it and plug it back in upon entering the power button the green light wouldn't even turn on either. After probing power supply voltages in jumping PS on to ground and inverter on to ground I found out the main board was at fault. So I figured what did I had to lose so I threw the whole main board in the oven at 385 degrees for 10 minutes. Worked like a charm TVs back to brand new. Just thought I'd share in case anybody runs into this particular model with this problem.
    I would probably try to reflow the processor next time instead do the fact that the buttons suffered minor melting at least it still work.
  • mmartell
    • Oct 2013
    • 3189
    Re: toshiba 40ft2u1 works cold
    Haha good job.
    • Shinju
      • Mar 2014
      • 1239
      I got a Toshiba doing some strange things when warm. If I tap it after about 20 min the backlights flicker off if I tap the unit again they come back on.
      Audio persists through this too.
        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
        I am comparing them to a brand new one that I installed
        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
        I going to let it run for several days before I remount back on the wall next to the...
        09-05-2024, 06:48 PM
        09-06-2024, 05:27 AM
      • PNI E.
        tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
        by PNI E.
        hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
        02-20-2025, 08:36 AM
      • zioricci
        Toshiba P855 only works with battery
        by zioricci
        I have a Toshiba satellite P855 that was previously stuck on the Toshiba logo and I couldn't enter the BIOS with F2 and then, thanks to the 2 original bios files that hardware1 gave me, yesterday I was able to boot it up to Windows 11. I deduced that the fault was the corrupted bios. So all the hardware works, hard drive, graphics card, RAM etc. The problem is that everything works if I power it with only the main battery, as soon as I take it out and put the charging cable in, the laptop, although it always succeeds entering bios with F2, hangs on Toshiba logo. I tried doing...
        03-31-2023, 01:24 PM
        09-06-2024, 05:59 AM
