samsung le40a656a
  • sordids999
    • May 2013
    • 2161
    samsung le40a656a
    Hello guys
    so i picked up the tv today with solarized images cleaned the lvds cable and reseated which made the tv picture go ten times worse,upon cleaning a second time to the tv would just keep restarting so tried a third time and now everything is ok picture is fine
    intermittent fault somewhere or is it just tricky getting the lvds cable right sometimes ?
    thanks
    Re: samsung le40a656a
    Could be main board fault-- I would run it for some time before calling it fixed. Not encountered dodgy LVDS on models using the "rigid" cables myself; it's always the flexible ones that are failing.
    I had a non-intermittent LE40A656 picture fault, bad T-con board. Mine was a repeated pattern across screen, every other 1/8th of screen was solarised. https://www.badcaps.net/forum/showth...light=le40a656
    I've also had bad tabs cause a dark blurry pic but I'd guess that's not what you've got.
    • sordids999
      • May 2013
      • 2161
      its a strange one if i just wiggle the lvds cable going into the tcon the solarized images come back im going to search around to see if i have another spare cable
        Try pressing on that black heatsink to see if the same thing happens.
        • sordids999
          • May 2013
          • 2161
          pressed on heatsink nothing changes tom
          update: change the lvds cable and resoldered on some points in the picture now it does not do nothing now once i wiggle the lvds cable at the moment but ill test it still
            While you're at it, worth cleaning the fan as it can make a loud noise sometimes while operating.
            • sordids999
              • May 2013
              • 2161
              already done tom
              • sordids999
                • May 2013
                • 2161
                tom
                question the tcon cover i ripped the silver tape while removing the tcon board which covers up the ribbons does it matter or get some more to replace ?
                  It is for EMC/EMI compliance. i.e. radio interference. Not a major issue, just try to stick down as much as possible.
                  • sordids999
                    • May 2013
                    • 2161
                    Thats the problem it all ripped while trying to remove it
                      It should be ok... just be more careful next time.
                      • sordids999
                        • May 2013
                        • 2161
                        yes boss i will in future and thanks for the help
                        • howardc64
                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                          by howardc64
                          • Prior owner tried a replacement main board. No difference.
                          • Samsung 2x red blinking standby LED = panel fault
                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                          07-19-2025, 10:54 PM
                          09-07-2024, 05:50 AM
                        • NolesFan
                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                          by NolesFan
                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                          10-24-2024, 06:36 PM
                          09-06-2024, 11:40 PM
