PROSCAN 32" TV Model# PLCD3271A-D no power issue
  • daveryder
    • Nov 2014
    • 13
    Hi all, I'm trying to repair a PROSCAN 32" TV Model# PLCD3271A-D, and I'm not having any success. (BTW I guess you should know right away I am strictly an amateur with very little electrical knowledge) I get no power light on front of tv, no picture and no sound. The PSU is AOYUAN model# AY118L-4HF01. I've replaced every capacitor (the dreaded Capxons) with equivalent values (Panasonic FM or FR). I get a steady 5v on standby, but with the cables plugged in all the voltages surge (or pulse) continuously, so that the meter on my cheap radio shack tester goes back and forth, rather like a metronome.
    Something I noticed right away was the burned spot in the lower right hand corner by the diode D16, so naturally I assumed the problem has something to do with that. I thought it was a Zener diode, but a google search took me to this page: http://szcanyi.en.alibaba.com/produc...ode_SR560.html which identifies it as a dip schottky diode SR560 (the MIC printed on the diode apparently stands for Master Instrument Corp. a china Co.). So I ordered what I hoped was an equivalent when I ordered the new caps and installed it, but that didn't help, so I re-installed the original one, which also made no difference
    On the backside of the board directly under the burned spot is what I believe is a mosfet diode, I wonder if that heated up so badly to cause the burn mark on the front of the board?
    I'm uploading some pictures of the PSU and a little diagram I scrawled with the cap values if that helps.
    Anyway, I would be grateful for any ideas or assistance anybody would be willing to share, I'm trying to get it fixed for my 12 year old son for a Christmas present, but right now it doesn't appear that I will be able to make that happen as time is running out. No worrys, though, mom made sure Santa is bringing him plenty of presents lol. Thanks in advance for any help, my name is Dave
    resistance is futile
    Re: PROSCAN 32" TV Model# PLCD3271A-D no power issue
    Can we see the whole back side of the TV so we can see how all the boards are connected together?
    Did you do the resistance test on the combination of all 3 pin on that power MOSFET?
    Please also provide the pictures of the whole back side of the power supply board.
    http://www.shopjimmy.com/westinghous...t-inverter.htm
    • daveryder
      • Nov 2014
      • 13
      Copy that Bud - give me a few minutes, and thank you for helping
      • daveryder
        • Nov 2014
        • 13
        Ok here are the pics - they aren't as clear for some reason, maybe I accidentally changed a camera setting - if you need cleaner pics I'll see if I can get them for you, but maybe these will work for you.
        • daveryder
          • Nov 2014
          • 13
          RE:
          the only thing I could check with my cheapo MM was resistance: with - on drain and + on source it shows 0 ohms (the same as if I touch the meter leads together). Sorry if I sound ignorant, it's because I AM ignorant when it comes to this stuff
          • daveryder
            • Nov 2014
            • 13
            I've still been working on this , I have a question: in my first picture on my first post, the diode labeled D4 (right above the big 450v cap) reads infinite ohms - do I have to remove it to test it, or does that mean it's shorted? If you look closely, you can see a green goo that seems to have oozed out of it.
            BTW I've ordered the new power mosfet, resistor and schottky diode located next to the burned spot, I'll update when I install them.
            • daveryder
              • Nov 2014
              • 13
              Also, on first post I said I replaced caps with panasonic FM or FR, what I meant was FM or FC series, I did read BudM's sticky on LCD TV troubleshooting.
              It's odd, I've been able to fix a Dell 32" tv and a Hanspree 32" (that was a tricky one, I did what Budm said where he replaced a surface mount transistor Q7 with a through hole (2n2222 i think?) and the zener diode zd4): https://www.badcaps.net/forum/showth...1&highlight=q7
              that's the hardest soldering I've attempted to date what with shaky hands and poor eyesight lol. but hey it worked - me and the boy play xbox on it everyday. so it's driving me crazy I cant figure out this proscan.
              • selldoor
                Slow Learner
                • 7870
                If you have not read it this is useful for many tests= start at post19
                https://www.badcaps.net/forum/showthread.php?t=10419
                • daveryder
                  • Nov 2014
                  • 13
                  Yes that is very informative, there is just so much info on these forums it's easy to miss gems like that. thanks. I guess I'll either start learning this stuff or my head will just explode from too much information. It's a risk I'm willing to take.
                    HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                    This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 05:27 AM
                    HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                    This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                    HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                    This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                    This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  • sofles
                    Macbook a1707 2017 model 820-00928 GPU issue
                    by sofles
                    Hello there
                    I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                    I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                    11-21-2024, 05:25 AM
