Panasonic EZ47VEB VHS/DVD recorder
  • Greeno
    • Feb 2011
    • 36
    • Scotland
    Hello again
    I have been attempting to fix a Panasonic EZ47VEB VHS/DVD recorder for a friend. The problem is no Freeview - blank white screen during tuning. I have found several references to a similar problem, but not for this specific model. Similarly, I have managed to acquire a couple of service manuals for similar models but none for this exact model.
    On initial inspection, there was a swollen capacitor in a location similar to other models. I replaced this, as well as a few others in the same area, but to no avail.
    The similar repair to other models talks about a U81 error (which I have not experienced), caused by a faulty voltage converter. It does not seems unreasonable to assume that the same component might be at fault here. However, without a suitable service manual it's difficult for me to identify and test this, especially since the suspected component on the board I have is not marked in the same way as the component in other models (identified as an MD5001T).
    In the first picture, I have replaced all the capacitors within the red box (C11711 was the swollen one). The second picture corresponds with roughly the same area on the bottom of the board - you can see that the board has been hot around the area of Q11700. I guess that the potentially faulty converter is either IC11700 or IC11370 (or perhaps their associated transistors, Q11700/Q11370?). These chips are marked "1016 817".
    Does anyone have any experience of this fault (maybe even in this model!) or can help me with a service manual, or can identify these components? Probably the same MD5001T?
  • Ady2017
    Panasonic DMR-EZ48V DVD/VHS combo - DVD recorder part not working
    by Ady2017
    I have recently inherited a Panasonic DMR-EZ48V DVD/VHS combo after my dad died. I tried to record a DVD with it and it worked for about 5 mins before it suddenly stopped. Since then it just keeps making a noise like it is trying to read a disk but then gives a 'no read' error message. I have tried numerous DVD's and it is definitely the recorder that is the problem. I did find a youtube video showing that capacitors on the power board were a common problem on these and so I went ahead and replaced the capacitors but it is still doing the same thing. I now think that it could be the laser that...
    06-06-2025, 08:05 AM
  • Andre Gilbert
    by Andre Gilbert
    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
    11-20-2024, 08:52 PM
    DVR recorder Switching power supply Failure
    by sam_sam_sam
    When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
    Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
    This...
    05-27-2023, 03:03 AM
  • BigPete
    Panasonic Heatpump Dryer Repair
    by BigPete
    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
    Unfortunately the whole machine has to come apart to fix it.
    I have...
    11-01-2025, 06:40 PM
  • AquaMan Ua
    by AquaMan Ua
    05-17-2025, 09:40 AM
