Panasonic Plasma TC-P42C2 Clicks 10 Times Help!
  • playab0yyy
    • Dec 2014
    • 37
    I have a Panasonic Plasma TC-P42C2 that is clicking 10 times with no screen or backlight. I don't know much about this stuff. New to repairing tv's. I've looked at the back and don't see any bulging caps (but that doesn't mean I'm overlooking something with regards to the caps). Suggestions for what I can do? Thanks in advance!
    Pictures:
    http://1drv.ms/1yH37ib
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic Plasma TC-P42C2 Clicks 10 Times Help!
    Check SS board TNPA5072, transistors Q021,022,001,002 for short cct.
    • playab0yyy
      • Dec 2014
      • 37
      Thanks! Ok, please don't laugh at my rookie questions. lol I found the board and transistors. Now, how do I check them? Do I need a voltage multimeter? (Not that I know how to use one, but I just bought one and am anxious to figure it out lol) Thanks again! I really appreciate the help.
      • tw2005
        • Oct 2011
        • 6458
        can you tell me what meter so i can see what i'm dealing with? needs continuity / diode setting or use resitance. Just probe any 2 of the 3 legs. the tab is the centre leg
        • playab0yyy
          • Dec 2014
          • 37
          Innova 3320 Multimeter. Mind you, I've never used one of these before. If you could tell me which setting to turn the dial to on the face of it (and save me a bunch of instruction reading time), that would be great. Also, do I need to have the tv plugged in or turned on?
          • tw2005
            • Oct 2011
            • 6458
            what's the rush? Hope you understand symbols, reading the manual will help. Turn the dial to the audible symbol below the diode symbol and the probe those transistors. If the first one shows short (continuous beep), not much point checking the rest.
            definitely do not have the TV on. About 200v goes to the board.
            • playab0yyy
              • Dec 2014
              • 37
              Yeah, I'll definitely end up reading it. I admit, I'm an instruction reader. lol Last two questions. Tv off, but does it need to be plugged in? And when probing, do I touch the black probe to the metal frame (ground) and the red to each leg of the transistor?
              • tw2005
                • Oct 2011
                • 6458
                unplug for safety, just find the transistors, pick 2 legs, and put probe on each, does not matter for this. just need to see if they are dead short
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  TBH--and Dont take this the wrong way
                  --A Plasma TV set isnt something I would recommend someone who has NO experience whatsoever--as in not even knowing what setting to use on a meter-- to attempt repairing....
                  Very serious currents and voltages flow around a Plasma panel, peaking at up to 450V, at 300 odd amps and can cause electricution and or serious damage to the set if the basics of safety (Which you may--or may not know....) are not followed.....
                  These are pretty complicated devices, and great care is needed in working on them....
                  In your case, Basic testing for shorts on the two SS/SC boards-- With The Set UNPLUGGED from the mains--can be done, and then the faulty board complete replaced, in this instance until you have built up sufficient knowledge to go further on a future project.....
                  Panasonic sets are well known as being TROUBLE to repair--even for guys of many years experience. Not a good 'Starter-Set' for anyone!
                  TELEFIX
                  • playab0yyy
                    • Dec 2014
                    • 37
                    Got it, tw2005. Thanks. I'll check it out tonight when I get home. And thanks Alastair E! I appreciate the heads up. I'll keep everything you said in mind. I've fixed two tv's so far (LCD's), but they were very easy, and I probably got a little lucky. Just a couple board swaps, which is what I'm hoping for in this case. My soldering isn't perfected yet either, so I'm kinda just hoping I can swap a board and be done with it. Also, coincidentally since you mention starter-sets... I have another post on here for an LCD with what you would probably consider a much more common problem. See link below. Again, I really appreciate you guys helping.
                    https://www.badcaps.net/forum/showthread.php?t=42462
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Here's a safety tip for ya, if working LIVE--
                      Keep your left hand--In yer pocket....
                      (Reverse if left-handed....)
                      Doing so, lessens the risk of electric current passing through the chest/heart and causing --Issues! Wont stop you having a belt--but could save your life.
                      TELEFIX
                      • playab0yyy
                        • Dec 2014
                        • 37
                        Thank you!
                        • playab0yyy
                          • Dec 2014
                          • 37
                          Update: (fyi - The 2 paragraphs below are different even though they initially sound the same)
                          Q001 and Q002 both responded the same way. With either probe (black or red) on the top and middle legs, there would be a constant audible sound. So, black on top and red on middle, or red on top and black on middle, there would be a constant audible sound. Any configuration with either probe touching the lower leg and there would be no sound.
                          Q021 and Q022 both responded the same way. With either probe (black or red) on the middle and lower legs, there would be an audible sound that would last about 2 seconds then stop. So, black on middle and red on bottom, or red on middle and black on bottom, there would be an audible sound that would last about 2 seconds then stop. Any configuration with either probe touching the upper leg and there would be no sound.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8352
                            Q001 and Q002 are shorted and need to be replaced.
                            • playab0yyy
                              • Dec 2014
                              • 37
                              Thanks CapLeaker! You guys are awesome!
                              • playab0yyy
                                • Dec 2014
                                • 37
                                PS - Is there a way for me to edit the thread title? I just realized I put "clicks" instead of "blinks".
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  not sure if you've done it right, the tab and middle stub are the same connection, so did you test middle to left or midlle to right or the 2 outer legas?
                                  • playab0yyy
                                    • Dec 2014
                                    • 37
                                    I only touched the side that had three legs sticking out. I guess maybe I shouldn't call the middle one a leg since it isn't as long as the rest. I'm assuming the tab is the single piece on the opposite side of the three? I didn't touch that side. As far as what I tested on the side with the three pieces sticking out, I tested all possible configurations with the two probes. And that was done on all four transistors.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      ok, so was it a constant beep then indicating short? if you set meter to resistance or ohms, your meter is auto ranging, probe across pin 1 - 3, the outer legs. what resistance do you get.
                                      • playab0yyy
                                        • Dec 2014
                                        • 37
                                        Q001 and Q002 both responded with a constant sound with the probes on the top and middle legs. There was no sound with either probe touching the bottom leg.
                                        Q021 and Q022 both responded with a sound that stopped after about 2 seconds with the probes on the middle and lower legs. Any configuration with either probe touching the upper leg and there would be no sound.
                                        I'll run the other test you're asking in a little while. Thanks!
                                        • fourroses73
                                          Panasonic Plasma TX-P46VT20 blinks 10 Times
                                          by fourroses73
                                          Hi all folks.
                                          My old Plasma TV blinks 10 Times when i try to start it. Its now 2 weeks that i search like an old donkey on internet and i try everything.
                                          Nothing smell or looks like burned. I think its the A board, but i did not find more infos how search error on the A board. Replace it its not an option: I dont find part for this TV in my country and if i give it to a repair shop its to expensiv...
                                          What i have measured:
                                          Vsus and Vda are ok
                                          Pin1 of connector P7 : 5V ok
                                          Pin1 and 9 of connector P6: 16V in place of 15V but...
                                          12-03-2020, 05:28 PM
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • Eaglecrest
                                          Panasonic plasma color stripe
                                          by Eaglecrest
                                          I have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?
                                          11-05-2025, 06:16 PM
                                        • SLB007
                                          Panasonic TX-32C300B stanbye light blinking 13 times
                                          by SLB007
                                          I get no image nor backlight, standby light blinks 13 times then stops. Any clues what it could be no evidence of damaged components
                                          11-02-2025, 04:08 PM
                                        • Lintesir
                                          Panasonic P42S30 Plasma - Pink sparkles
                                          by Lintesir
                                          My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                                          There is about a 5cm high region at the top without any sparkles,...
                                          07-26-2024, 03:16 AM
