Vertical lines and ghosting on Mitsubishi LCD TV
  • westgst
    • Dec 2014
    Wondering if anyone can help me out with my tv. It has 3 vertical lines and ghosting. I have not been using it since August and tried turning it on and doing factory reset but it didnt fix it. Model is LDTV-146 - it is a costco re-branded model and Mitsubishi support doesn't even have any record of that model number. There is a discussion on this forum (http://www.avsforum.com/forum/166-lc...6-ldtv152.html) for the correct model for the unit but I do not think there is a concensus on what it really it.
    This is how it looks like - very horrible ghosting on the TV
    https://www.youtube.com/watch?v=wA7lNfNltoI
    Vertical lines photo here
    Thanks in advance!
    Re: Vertical lines and ghosting on Mitsubishi LCD TV
    Unfortunately, to me, it looks like the LCD panel in your TV has failed. This can happen spontaneously or due to moisture ingress. This would not be economical to repair as the panel is usually 90% or more of the cost of a new TV.
    • westgst
      • Dec 2014
      Thank you! That's what I needed to know to justify getting a new set. Wanted to make sure I wouldnt be able to fix the tv first
      • truep
        • Aug 2010
        • 373
        They use a samsung panel, Very common fault with those panels.
        • Stanley1843
          Screen Display Vertical Multicolor Lines
          by Stanley1843
          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
          06-29-2024, 11:54 AM
        • gpo23
          Sony KDL-40V3000 - Vertical lines
          by gpo23
          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
          With the new t-con the color are good but there are vertical lines on all the screen :
          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
          Is there a way to fix the vertical lines on the new t-con ?
          Thank you for your help
          gpo23...
          10-04-2023, 09:11 AM
        • Firentiosi
          1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
          by Firentiosi
          Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
          The issues are as follows: the...
          11-27-2024, 12:33 AM
        • viking509
          vizio e65 e3 LED tv color vertical lines center tv only
          by viking509
          I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
          03-21-2023, 12:48 AM
        • rfxcasey
          Vertical Lines on Half of LCD Display
          by rfxcasey
          I have an Siemens HMI with vertical lines on half of the screen. These lines aren't scrambled garbage but rather very regular in pattern and color. I have replaced the LCD with a new one and still the problem persists. I'm wondering if this isn't indicative of a bad video process chip or video memory? Any help would be appreciated. The cable appears to be OK but one pin on the header is unpopulated, though there isn't any loose wire to suggest one broke off or popped out of the connector. In the picture below where the connector is busted out of the side, I did that with my small screw driver...
          05-16-2024, 06:52 AM
